Question about Sony SDM-HX93 19" LCD Monitor
Dead monitor Before completely going dead the monitor would intermittantly go blank (working fine then go black also no pwr lite) approx 5 times within an hour. The black out time was approx 1-2 sec's then return to normal. Today it went black and stayed out! Things I have tried: (removed covers) 1) Internal AC fuse is good 2) removed and re-installed all cables to the power supply 3) removed pwr/spy pcb for close inspection then twisted or flexed the pcb and re-installed. 4) found the +12 & +5v outputs but measure 0v dc Willing to try most anything but stuck as what to do next!
  • 624 Answers
SOURCE: Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Posted on Mar 16, 2007
  • 624 Answers
SOURCE: Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
  • 624 Answers
SOURCE: My monitor says "input ......" and then the screen flashes off.
  • 236 Answers
SOURCE: Help!
You have a button stuck either on the set itself or on the remote. Stargazer
Posted on Aug 20, 2007
bkvinr
  • 76 Answers
SOURCE: Sony KV-27FS100L -
This is due to switches malfuction due to corrosion in switch and dust accumulated in the switch. Since you rarely used switch now after failure of remote of remote control you tried to operate the switch. Another thing you said did"t get picture, maybe memory problem is there. This can be sorted out by the technician only.
Posted on Sep 06, 2007
Have a kenmore he4 front load gas dryer. It would go completely dead like it had no power... intermittedly working... we replaced the control board. Seems to come on fine now however the end of cyc
is the dryer sensing strips clean? Could be some dryer sheet goopus on them causing intermittent sensing to clothes?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 28, 2017 | Dryers
Dell 1800fp dead
Each monitor has a different response to "no activity" from the system. So for the monitor, if you get a chance, try your monitor on another machine that you know does function. At work, neighbour, or other.
For the computer, does the it (beep) or POST (Power On Selft Test) when you turn it on, do you see and hear what you would if the monitor was connected?
If it sounds normal, then everything should be fine and luck might have it, your backup monitor is not working either, try another one from the same friend or neighbour above.
If it doesn't POST, you could have a video or other card or ribbon connection loose in the computer. Either you or a friend, or the service center, whichever feels comfortable reseating all the external and internal equipment, bearing in mind static electricity and proper handling measures for the computer.
Nov 26, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I have the Canon Rebel T3i and having troubles with the LCD monitor. When I turn the DSLR camera on, the camera works perfectly fine. I can take pictures and the camera itself works perfectly. The...
Possible dead LCD? try these
1.press the play button to see if you can view photos
2. press the "disp." button near the shutter
if these fail. send it back for warranty
Jul 04, 2011 | Canon EOS 600D Rebel T3i Digital Camera
My HP monitor was working fine then randomly one day it went dead, I turned it back on and I could see the screen and what it displayed for about 2 seconds, then the screen dies again. The power button is...
Sounds like your monitor is going dead. If its under warranty that would be the best way to go. Specifically it sounds like the power inverter is dead or there is a busted capacitor.
Mar 12, 2011 | HP Pavilion F1703 17" LCD Monitor
Blank screen - appears to be dead
If the screen is completely black, your screen may indeed be dead. There are a few solutions you can try before throwing in the towel though.
1) Test the monitor on another PC if you can.
2) Make sure the contrast, and brightness aren't turned all the way down.
3) Make sure the graphics card in your PC is functional. You can easily test this by connecting a known working monitor to your computer.
If these steps do not resolve the issue, and your graphics card is in good working order, you indeed have a dead monitor on your hands. It may be cheaper to buy a new monitor, than to have that one serviced.
May 30, 2009 | Sony GDM F520 21" CRT Monitor
Satelite Toshiba M45-S165. WOrked fine, now won't boot
To sure the battery problem or bad. try to change another battery for testing only befor you replace at all.. I thing this over charging of the battery. then the battery became damage or bad.. to sure change other battery..
Thanks
May 11, 2009 | Toshiba Satellite M45-S165 Notebook
Monitor went black completely dead
Hi...there,
A simple way to check your AC Adapter, plugged into a socket and see if it lite green... If you don't see a green light lite on the AC Adapter, then it's DEAD... You can order the AC Adapter @ www.3rd-rocks.com but sometime you need to replaced both. Have a nice day!
Nov 17, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Blank screen
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen .
E-mail CHID: 5858 All it says is Error loading operating system on a black screen. Answer. This issue is often caused when the computers BIOS.
Read & Follow instructions/ Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Lenovo ThinkPad T61 Notebook
Display stopped working
My Alpine CDA-7842 works fine from a functional point of view but the display (readout) had stopped working. All the lights on the display work but the actual readout is blank. At first the readout would intermittently work now it's completely dead. Any assistance would be greatly appreciated.
thanks
Oct 26, 2006 | Alpine CDA-7842
Sony SDM-HX93 19" LCD Monitor Logo
26 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
