Maytag Epic Z
I bought my Epic Z washer in April of this year. I told the salesman I lived on the second floor in a condo and needed something that was quiet and that would operate with no shaking on the second floor. A few months later, I have had a service dept out three times, as there is a horrible vibration in the washer and it 'walks' around my laundry room when it spins. The service men seem to be stumped, the applicance store has done nothing, Maytag says it's an unstable floor. So am I out $2000? This has been extremely frustrating.
  • 2 more comments
  • Auriel100 Oct 19, 2008
    Thanks, I will give it a try!
  • Anonymous Jan 28, 2009
    I have the same problem. My washer is on the top floor of my home and it vibrates a lot. The vibrations is noisy and shakes the entire up stairs. I have have it for about four months and now the belt has broken. I am curious to know whether the excessive vibration caused it the break so soon.
  • notthefloor Mar 11, 2009
    We have the same problem. Extreme vibration on the ramp up spin. We have fought this out with the retailer and now Maytag has said it is issuing a new installation kit for this machine. Apparently the washer/dryer have to be separated.
    Trust me, It is not your floor, it is not your fault. It is a defective washer. They also replaced the bellows.
    clothes are not clean, mold odor and shakes all over the place.I thought the dryer was going to come off the top of our stacked pair.
    don't give up and don't let them tell you it's your fault. It is not.
    and BTW, the vibration pads do not help this issue.
  • Mr Fedup Mar 16, 2009
    I have the same problem with excessive shaking and I just had the repairman here and he told me that the only fix was to put it on concrete! My floor is 3/4 inch tongue grooved plywood with 1/4 inch concrete board with tile on that. I have no concrete to put it on. I know I will never recommend a Maytag front load washer to anyone.
Do you if these gadgets work with pedestals. I bought the Maytag pedestals for both washer and dryer.
Posted on Oct 24, 2008
It is not the washer/dryer. I have the Epic Z stacked...in my laundry room which is concrete is the perfect solution. It does not jump like you suggest.....the problem is that most floors not in the basement are not built for laundry facilities....my husband has been in the biz for 30+ years and he is adamant, to this day, all washers and dryers should be in the lower level on a concrete floor.
Posted on Jul 15, 2009
  • Lmhk Feb 19, 2013
    I have the EpicZ set, its on concrete and vibrates horrible. Dances all over the floor. We have done everything in our power to correct, even used door stops and supports to keep this washing machine in place. Nothing works. Very reputable appliance repair man told us to save our money and replace as these units are known for this and he could come out and work on it but it would most likely be cheaper for us to replace. He has worked on these many times and says they have a poor history! Don't waste your money, regarless where you will be putting it in your home, concrete or not,basement or not.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Heres a product that might be helpful http://www.apwagner.com/index.php?main_page=product_info&products_id=148095 really had good results with this since inroducd a year ago, $ 30 bucks its worth a shot!!!!
Posted on Oct 19, 2008
Bought GE Washing Machine but have 4 prong outlet
get in an electrician to fit the correct plug to suit the outlets
May 22, 2017 | GE Washing Machines
I have a maytag epic z washer and drier The washer sometimes shakes so much the machine moves 6" other times it works perfectly . It's on the second of our house ( our house was built 1909 . We had a...
Check under the machine and locate the adjustable feet. Screw the feet in as far as practical, the further the better. Feel the machine for steadiness and rocking and adjust the foot that shows clearance until it is firmly on the ground and the machine no longer rocks. Check that machine to see if it is level, with a front loader this is not critical, but it should rather not be out of true by a large amount, the important thing is that there must not be any movement on the machine's feet and the machine should not stand too high on its feet either.
Mar 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a slow drip at the bottom of my front load washer door (Maytag Epic Z). It leaks through the bottom of the door and drips down the front of the washer onto the floor. Has done it since I bought it...
Yes the seal might need replacing. but in my experience a simple strand of hair caught on the seal will make it leak. So i suggest that you try thoroughly cleaning the seal fist. If its needs to replaced, its not that difficult, but its kind of tricky. Check if your machine is still under warranty by contacting the manufacturer. hopefully it is and they will change for you for free. If its not under warranty let me know and i'll try my best to give you detailed instructions on how to change it.
Feb 06, 2011 | Maytag Epic 7.0 Cu. Ft. Super Capacity...
110 20902990 Kenmore washer first cycle is fine but tub doesnt empty or spin you can move the knob around and maybe get lucky but then it will not do a second cycle. It just washes and doesn't...
this is a whirlpool built washer sounds like a timer problem # 3953248 $109.00 i would reccomend replacing unit just becareful not all kenmore appliances are whirlpool made anymore.... so if you like your old washer and you decide to purchase kenmore brand ask salesman if its whirlpool built
Jan 26, 2011 | Washing Machines
We have a sub-zero refrig/freezer that came with our condo. Condo built in 1985. We purchased 12 years ago and were the 1st owners. This was originally the model and not lived in but very rarely by one of...
After 12 years you can expect that kind of repairs...I would not spend the 1200 for the compressor and would instaed replace the unit...it will just irritate you more from here on...
heatman101
Aug 30, 2010 | Kitchen Ranges
Shakes wildly and loudly in spin cycles
The bearing has gone bad and will need to be replaced. It is located towards the back of the machine and so the back panel will have to be removed to access it.
Aug 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Got much noisier over time
Hello Hunting2000 the noise could be several things. If you heard what is water hitting against the inner door, try aranging the dishes so that the water is hitting the dishes and not the door. I assume however this isn't the noise you are talking about. Sometimes over time the wash arms themselves will start to make noise. This is from wear. Yes less than a year sounds like a short time. This could have been there from the start. I would call Bosch Customer Support and see if they will pay for a 2nd opion. This well could be the wash arms causing this. Espically the top one not sealing proper and allowing water to hit the front. Hope this helps.
Jan 28, 2008 | Bosch 24 in. SHE44C05UC Stainless Steel...
Washing Machines Logo
1,181 people viewed this question
Top Washing Machines Experts
