Minolta copier ep2152
I,m getting long black streek marks on my copier. what should i do?
  • 1,326 Answers
If you are asking about a ep2152. That is a very old copier, they may not make part for it. Let's try, do you have what looks like a front view of a camera lite up orange or flashing? If so, you need a new IU unit/ drum & cln blade & developer most likely sold sepperate. I don't think they make the whole unit as one piece. I could be wrong. Try making a copy with the IU unit out. If the marks are on the blank page that comes out, it is in the fixing unit.You will need to replace the upper fixing roller & lower roller & cln roller. If you put the IU unit back in and the line is there then you have to rebiuld the IU unit. Good Luck....
Posted on Oct 18, 2008
Why there is black mark in the back page of copied page in Ricoh FT-4822
Does the black mark only appear when you copy through the doc feeder? if so there is a slit of glass alongside the main glass, clean thisa thoughly with glass cleaner and retest. if the black mark is still there contact me.
Jun 26, 2014 | Minolta Di3510f Bizhub Copier
Paper jam
Where is it jamming that is a very old machine has the bicycle chains in the back for some drives:) WOW I have worked on them this is a desktop one correct small
Feb 16, 2014 | Minolta Office Equipment & Supplies
Copy quality
run the CLEAN mode.
or
Remove the toner cartidge and clean the rollers.This happens when you use cheap paper. The dust gets on the roller drum and grays or streeks the copies
Apr 04, 2013 | Lanier Office Equipment & Supplies
Black streacks on paper during coping
Odds are that you will need a new OPC drum & drum cleaning blade for the black lines > you may also, need a new primary charge roller & it also, depends if the black lines or marks may be coming from the fixing unit..... There are a lot different cause's.... Good Luck
Sep 06, 2012 | Panasonic WORKiO DP-2330 Copier
Visible "streek" down the length of my copy
usually this is caused by dirt or wite-out on the scanner glass. List the feeder and clen the scanner glass.
Nov 23, 2009 | Office Equipment & Supplies
Black color streeks. Cleaned 3 or 4 times to get
it seems youu already did all the troubleshooting.
Heres the thing you need to do:
-Try to reseat the printhead then calibrate printer., you can calibrate printer by pressing menu scroll down and look for calibrate printer.
-Please download your latest firmware at kodak.com/go/downloads
If the steps did not solve the problem it means that the nozzles of the printhead is defective you may call kodak for repair Toll Free 1 800 421 6699., GudlucK!
Nov 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
HP L7680 black print streeks every 5-6 lines
Any inkjet printer with this problem is caused by a build-up of ink on the undercarriage or the wiper assmbly.Usually on the right side where the cartridges are at rest. You have to get messy and clean that build-up with moistened cloth, qtips etc.
Jul 30, 2009 | HP Office Equipment & Supplies
77 people viewed this question
jasbo
jasbo
