Question about Mitsubishi VS-60601 60" Rear Projection Television
Mitsubishi VS-60601 60 in. Rear Projection Television Concave
The left side and bottom of the screen is concave and the red and blue won't match up can some one help me?
    President:
  • 3,130 Answers
You have a convergence problem my friend. Theres nothing as an alighnment or adjustment you can do unfortanatly as there are no user serviceable parts in these sets unless your a tech and know your way around a projection tv as there is alot of voltage inside these puppys when its off. But Its most likly the Main convergence driver IC's and most repair such as this require alighnment afterwords as well so the average reapir cost on a set with this problem would be about 250 to 400.00 depending on if theres any other componets that fail at the same tim?? Sorry couldnt assitya more But if you need to contact the main company at this addy CustomerCare@meus.mea.com and see if they can direct you to a reliable servicer. Good Luck
Posted on Jun 06, 2006
I have the same problem, but i didt myself
replaced the convergence ics if you have concave triple colored images on the screen.
Jul 17, 2009 | Mitsubishi VS-50705 50" Rear Projection...
I have a Mitsubishi Rear Projection tv (vs-50705). The picture shows a concave image on the top and bottom of screen and the edges go off the screen. I have red blue and green ghost images on the screen...
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
Jun 06, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Turned TV on and screen has a concave look to it.
change the convergence chips or lack of voltage in the chips get advice from tech never your home
May 04, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Colours serparated, not converged, screen looks concave
Replace Both fo your STKs convergence ICs STK392-040s. For Parts Call 1-800-223-3205
Dec 30, 2008 | Samsung HC-P4741W 47" Rear Projection...
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Red and blue colors go across the screen. picture looks concave.
Greetings joanne7,
The issue you are having could be caused by your television needing the convergence adjusted. During production your televison has the three picture tubes that are converged to form a single image on the screen. Over time these can come out of adjustment.
If you go to this link http://download.jazel.net/misc/filecache/b8/b89bca4c8b740315d378e8ed030461c5_1227-517SeriesOwnersGuide.pdf and check pages 57 and 58, it gives you a very detailed guide on adjusting your convergence. I am aware this model number is slightly different than yours, but I own a 47" Mitsubishi and this is the exact procedure we use to do our convergence so I am confident it is fairly universal.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi VS 45501A Projection TV
Model VS-45501A  probably not worth fixing at around 400.00
for a convergence circuit overhaul......T.
Oct 20, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
