Question about Dell Inspiron 1501 Notebook
Cd rom not working
I have a dell inspiron 1501 and the cd rom dont work it opens and show the light flashing but other then that it wont work
  • bbybybg4v Oct 18, 2008
    that did not help at all
  • Anonymous May 02, 2009
    I have the same situation
  • Dell Master
  • 998 Answers
Try reseating the CD drive. Remove the battery and make sure the AC adaptor is not connected. Turn the laptop over and locate the locking screw. It will have a little "Pad Lock" symbol next to the screw. Once phillips screw is removed, pry the securing screw tab to push the drive from the chassis with a screwdriver. Re-insert the CD drive and fasten the screw back into the bottom of the laptop.
If you still have an issue with the CD drive, please feel free to contact me for futher diagnosis.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Posted on Oct 18, 2008
Dvd drive won't open
http://www.pchelpforum.com/cd-dvd-rom/75829-dvd-drive-wont-open.html
click here and read the many solution, aplly one which will suits according to your problem
thx
Jan 07, 2012 | Dell Inspiron 1501 Laptop
Dell Inspiron 1501 CD-Rom wont play.I can hear it start to spin.Can play stored music.Have no CD Rom or filters showing under "Device manager".
If the CD-ROM drive is not being detected under the device manager, chances are that either the power/data cable is loose or the drive is dying. To check the cables, turn off the power, unplug the power cord, open the case and examine the two plugs behind the drive. Touch yourself to something metal first to discharge static electricity.
If it turns out the drive is dead, then luckily drives are usually very cheap to replace. Somewhere in the line of $15 usually.
Mar 07, 2011 | Dell (6T980-A01) CD-ROM Drive
Dell Inspiron 1420 Factory Setting Recovery
back up all your files first because everything will be wiped out.
Turn on machine, Put the recovery cd on the cd rom drive, before it boots to windows hit the F1 to go into bios, on the startup set the cd rom the primary to boot machine on cd then follow the instructions from there..
Jun 30, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Cd rom
replace the CD Rom, they are available on the net. You may pay $35-$50 and you'll be home free. You may even find an updrade i.e. DVD burner, etc. They are also very easy to replace - one screw on the bottom of laptop and just pull the CD unit out.
Jan 05, 2009 | Dell Inspiron 1501 Notebook
Cd/dvd rom not working
go into device manager and see if your drive is listed or has an exclamation point beside it.if you dont know how to open device manger go to start menu and click help and search device manager.if there is an exclamation point ! click it and it will tell you the problem.you may need to download a new driver or reinstall the old driver. the only other possibility is the drive is dead :(
Nov 14, 2008 | Dell Inspiron 1501 Notebook
Dell inspiron 1501
Try going to the drive, in my computer ** should be named CD/DVD Or D: E: right click and press eject. Alternatively:-
if you look carefully at the dvd drive, it has a small pinhole in the front drawer. push a paper-clip sized piece of metal, or small jewellers screwdriver into the hole, this will force the drawer open.
mike @ compurepair.
Nov 05, 2008 | Dell Inspiron 1501 Notebook
Dell batteries.
Its time change ur batteries
Aug 16, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
821 people viewed this question
Alun Cox
