Question about Cyberhome DVR 1600 DVD Recorder
Won't Format disk.
Goes through the format procedure then stops at 98%. Waits about 2 minutes then puts put message that it can't recognize the disk
  • Michael Hoffman Oct 26, 2008
    Used a Sony and something labled "GQ". Same result on both,
  • 4 Answers
Try a brand name recordable dvd+r
Posted on Oct 25, 2008
My USB giving message of Insert a Disk into drive !
Your USB IS DAMAGED TRY TO PULL OF THE COVER OF THE USB DAN CLEAN IT WITH A TOOTH BRUSH OR ANY SOFT BRUSH DAN PUT IT BACK TO YOUR COMPUTER AND GO STRAIGHT TO MY COMPUTER AND FORMAT IT USING QUICK FORMAT SYSTEM. :)
Apr 16, 2010 | Electronics - Others
When I am put my 8 gb Transcend usb deive into pc, the message come ''u need 2 format the disk in drive I:b4 u can use it'' ,ten I click on format disk, a message come ''windows was unable 2 complete the...
First I would advice to try to format it via disk management.
Second is try to format via CMD menu.
ok
try this.
To open disk management go through:
Control panel>administrative tools> computer management> then disk management on the left> then right click and format fat file system or as per to your convenience...
Mar 19, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
Using windows dvd maker vista with sp1 starts to burn then at about 98% get error message and stops the burn. also when i try to format a dvd disc ready to burn that wont work and the dvd drive d is...
two things. Firsly make sure that you are using the correct disks i.e if your drive is dvd-r then only use dvd-r disks, if its dvd+r then only use dvd+r disks if it is a multi drive then it won't matter what disks you use. Secondly don't format the disk first. If it asks you to format the disk click on the X to shut the pop up box. Only put the disk in when dvd maker asks for you to insert a disk.
Oct 22, 2008 | Computers & Internet
How do I re-format a 2x serial SATA drive to reinstall XP?
How to Format a Hard Disk
After you create the partitions, you must format the partitions:
Restart your computer with the Startup disk in the floppy disk drive.
NOTE: If you are using a Windows 95 Startup disk, a command prompt is displayed and you can skip to step 2. If you are using a Windows 98, Windows 98 Second Edition, or Windows Me Startup disk, select the Start computer without CD-ROM support menu option when the Windows 98 Startup menu is displayed.
2. When a command prompt is displayed, type format c: /s and then press ENTER. This command transfers the system files and should only be used when you format drive C (or your "active" drive). For all other partitions, type format drive: (where drive is the letter of the partition that you want to format).
NOTE: If you receive a "Bad command" or "Bad file name" error message, you may need to extract the Format.com tool to your boot disk. To do this, type the following command at a command prompt, and then press ENTER:
Extract ebd.cab format.com
After the Format.com tool is extracted to your boot disk, type format c: /s t a command prompt to format your active partition, or type format drive: if you want to format a partition that is not your active partition.
3. When you successfully run the Format.com tool, you receive the following message:
WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
Proceed with Format?
4. Press Y, and then press ENTER to format drive C.
5. After the format procedure is finished, you receive the following message:
Volume label (11 characters, ENTER for none)?
NOTE: This is an optional feature that you can use to type a name for the drive. You can either type an 11-character name for the drive, or you can leave it blank by pressing ENTER.
Jul 25, 2008 | Computers & Internet
Jeeva1
hi jeeva,
to format ur hard disk simple way installed ur window xp/vista from installing the operating system it will be easier to format ur hard disk
steps1;
1) just put bootable windowsin ur cdrom
2) run the set up
3) follow the procedures while installing from there u can format ur hard disk
regards
shailesh
Mar 10, 2008 | ASUS K8S-MX Motherboard
Cant transfer footage from Canon DC201 onto computer (and eventually internet) Do I need specialist software to take video from DVD to computer?
You don't need specialist software to take video from DVD to computer.
One of two things has gone wrong
1. Your PC cannot read the -R DVD format, or, more likely
2. You have not finalised the disk.
You must finalise the disk in the camcorder before putting it in the PC. To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then go to the main menu, select 'disk operations' and you'll see an option to finalise disk. Don't move or shake the camera whilst the finalising step is underway.
Once finalising is complete, put the disk into the PC.
Mar 09, 2008 | Canon DC210 DVD Camcorder
Boot hang after formatting of hard drive
no there isnt, you need to take it and put it in another computer as a slave drive. But you might have damaged your hard drive, you can try Hiren's boot cd from here www.phazeddl.com but personally i think you might have messd up the drive.
to install as a slave
1.) find a working computer
2.) put hd in as slave (do not remove old hd)
3.) boot
4.) it will show up in my computer
5.) format and unmount drive
it the computer fails to boot ensure you got the drive connected propperly and jumpers are correct
it thats all good then your drive is damaged
Jan 02, 2008 | ASUS P5GD1-VM Motherboard
Cyberhome DVR 1600 DVD Recorder Logo
75 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
