Question about Radio Communications
Can you help
The chanels scan,but there is no volume when it stops on a channel
  • 204 Answers
Hello, with the limited info you supplied, I'd say offhand that #1 The volume control is dirty,or #2 The seaker inside the scanner went dead.(not uncommon) If it's a dead speaker, simply go to Radio Shack or a truck stop and buy an external speaker for a CB radio and plug it into the back of the scanner,, Hope this helps,, let me know,,, Mechanic
Posted on Nov 01, 2008
Grecom psr-200 .when scanning weather chanel comes in .what is problim.
IF you have a weather frequency programmed in as a scanning channel, it will stop on it everytime, so you need to go to 'manual' on the weather channel, and press 'lock-out' so that it isn't on during scanning. You can still manually go to that channel, but it won't stop while scanning that way. Good luck.
Nov 17, 2012 | Grecom PSR-200 Desktop receiver, analog
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Aug 08, 2009 | Televison & Video
I cannot find the code for my (ilo) brand TV from Wal-Mart and after the scan the scanner does not pick up on a channel I know is there. My friend has the working channel on his digital TV, but it...
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no signal.works ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
Feb 21, 2009 | Televison & Video
Cant get all of my channels
I LOST MY BOOK HOW DO I PROGRAM MY RECEIVER
Feb 18, 2009 | Motorola DCP-501 Receiver
I have just installed a GPX KCL8806DT, i cannot change the chanel or adjust the volume with the remote control....or even manually
I had the same problem. After running the channel scan off the menu keys,( which by the way didn't work the first time ) it did correct the problem, it also took several minutes to complete the scanning.
Hope this helps.
Jan 28, 2009 | GPX KCL8806DT 7 in. Portable Television
Program channels
Just Press Menu> scroll or Navigate or Select Auto program, then press enter> (to Move press volume button -minus or +plus,and to enter or OK press TV / VIDEO) then select auto program to automatically scan channel. Choose Air if you use outdoor antenna,if cable choose Cable,whatever the result ,just post so i can assist..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
JVC dual channel bridgeble Amp
Most repair shops offer a warranty. If you've recently had it repaired, return it to the shop to have them check it out. If you continue playing it as it is, more damage may occur and the additional damage isn't likely to be covered by the warranty.
Jul 01, 2008 | JVC KS-AX4750 Car Audio Amplifier
Programing channels
Check your tv set, set it on outo program scan set it into CATV.
Apr 11, 2008 | Memorex MT1134 13" TV
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Radio Communications Logo
74 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
