Question about Samsung PS42P2S 42 in. Plasma Television
Plasma switching between
My Samsung PS42P2SBX/XEU seems for some reason to be switching between AV1 and AV2 continously by itself. Not sure if this is something that has been accidentally pressed on the remote control by the kids or if it is a fault. Please help i am rather frustrated. Thank you.
  • ospi5 Dec 15, 2008
    NO SIGNAL IN EURO
    Champion:
  • 217 Answers
Sounds like a loose or pinched cable inside the set
Posted on Apr 30, 2007
My p.s3 will not work on my 42 inch plasma t.v.i used to use an hdmi cable to watch it now im using a.v cords how do i reset or fix the settings it was on before?
Go to the main menu of your tv then try to select for the video input, you will see there the inputs tv or av1,av2, hdmi1,hdmi2 etc. try to choose the av1 or av2.
May 14, 2011 | Televison & Video
I need remote codes to program my directv control to my bd p-1500 blu ray dvd
hi,
Try any one of the following code.
20490, 20573, 20820, 21075, 20899
Progarmminig procedure
The AV1 and AV2 switch position can be used to program a
VCR, DVD, STEREO, 2nd DIRECTV Receiver or 2nd TV with
the following instructions.
1. Turn on the component (e.g. DVD Player) you wish to
program.
3. Move the slide switch under the AV1 (or AV2) icon.
4. Press and hold the MUTE and SELECT keys at the same
time until the green light under AV1 (or AV2) flashes
twice and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of component being programmed. If performed
correctly the green light under TV will flash twice.
6. Aim the remote at your component and press the power
key once. The component should turn off. If it does not
turn off, repeat steps 3 and 4 trying each code for your
brand until you find the correct code.
7. Repeat steps 1 through 6 to program a new component
under AV2 (or AV1).
ok
Feb 21, 2011 | Samsung BD-P1200 Blu-Ray Disc Player
What input or channel does my samsung plasma tv need to be on to play the nintendo wii
If you have the AV inputs, use them. Use AV1, not AV2.
(If you use the AV2 input, there might be action delay between the controllers and the Wii.)
If you don't, just select VIDEO 2.
Dec 26, 2009 | Nintendo Wii Console
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Sep 05, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
NO AV1 AND 2 VIDEO SIGNAL
tv start working on its own.
Jun 26, 2008 | Samsung Televison & Video
Plasma tv connection to pc
when you say you have even changed the settings to pc...do you mean you have used PC..to try connect...through settings..??
I would have thought on the remote there is a button for setting up the Plasma TV? you checked to make sure there isn't a menu where you can tell the TV its connected to a PC??
It may be you will have to switch between the two. My reason is that on my TFT..there is a menu....when I check the list..there is an option to connect to PC..AV1 AV2.
With your lead connected you should get something?
hope helps
Feb 13, 2008 | Computers & Internet
Plasma TV PS-42Q7HX/XSJ
hey, i had this problem with a CRT television once. My subwoofer would cause the same issue in that TV. There is a rather large magnet in the subwoofer that creates a field that will mess your TV up if it's too close to it. not sure if the same applies to the plasma, but i'd definately move it more than 5 feet away from the screen. sometimes it takes 24hrs or so for the tv to repair itself after doing so. hope this helps.
Sep 27, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung PS42P2S 42 in. Plasma Television Logo
162 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
