Home | Canon | PowerShot A75 Digital Camera | LCD Screen = Kaput?
Canon PowerShot A75 Digital Camera
Problem for Canon PowerShot A75 Digital Camera
LCD Screen = Kaput?
By J656 on Jun 05, 2006
I was taking pictures with that rapid-picture setting (forgot what it's called) and my LCD screen suddenly went blank. It looks like no power is going to it whatsoever. The camera still powers on and when and I can take pictures with it (the flash still goes off) but nothing shows up on the screen anymore.
I've changed batteries, reset the camera and removed the memory card, but the problem persists.
My camera is more than 1 year old.
Is there any hope?
Comments:
Jun 09, 2006
- I don't think it's a shutter problem because not only was the screen dead when I was taking pictures, but also when I was in the mode where you can review all of the pictures stored in your camera.
A wire must have been loose or something because I turned it on today and now everything works fine again.
Weird.
Jun 10, 2006
- I was messing around with my camera today, taking single shot pictures, and the screen went out again. Everything else appears to be functional.
I guess I need to look into getting a new camera.
Best Solution
posted on Nov 15, 2007
Helpful)
t00nz
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 91%, 1993 votes
Know this is an old post but... Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Comments:
Was this helpful?
Yes
No
Solution #2
posted on Jun 08, 2006
Not Helpful)
silly girl
Rank: Wiz  Cameras & Camcorders  Expert
Rating: 81%, 3605 votes
It's a wild guess, but I have a visual image of the shutter mechanism getting stuck during the rapid release thing. I heard it can sometimes be fixed by tapping gently on the lens area.
Whatever comes to mind has to do with the camera being over taxed during that shooting session, and something got jammed or blown.
Hard to find someone qualified that will work on digital cameras for less than the fortune the manufacturers ask for, but it won't hurt to look. You could call Canon and tell them what happened, say that it's hardly over a year and that it's likely a design flaw with the rapid-picture thing. maybe you'll get lucky... ;=]
When you changed batteries, how long was the camera battery-less?
If not long try resting it sans battery for a good few hours, maybe it will come back from the dead.
Hope you find a way, let us know
Comments:
Jun 11, 2006
- Now that you say this, I'm not sure it's as hopeless as you put it. You're having an intermitent problem, it could be that it might be solved with a minor fix of soldering, or doing something to the LCD connection.
Canon would probably give you a high flat rate, but if you like the camera enough, before throwing it out try finding a repair shop that will give you an estimate on it. You might find out its a <50$ job and it's worth keeping.
Good luck
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A75 Digital
Questions and Unsolved Problems for Canon PowerShot A75 Digital
Do you recommend Canon PowerShot A75 Digital Camera?
Answer
Answer
, Bonjour ma camero ne fonctonne plus. Capteur d'image. Est-ce que &#231;a s'arrange?
Answer
My camera suddenly started asking for "fresh batteries" but even with new batteries, the... (More)
Answer
how do I download pictures from canon powershot A1000 to computer
Answer
my camera does not take photos.The image on the display is black. what can I do to solve this... (More)
Answer
I can't put my A75 on , I changed the batteries and it doesn't work either
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot A75 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
