Question about Philips 107G66 / 17-Inch / 1280 x 1024 / Black / CRT Monitor Refurbished
Remote intermittently won't work with tv
I have a 52" Philips tv and the remote will only work intermittently. I have changed the batteries, bought a new remote & new batteries, cleaned the sensor...I think the problem is with the TV sensor???...Any ideas appreciated. Thanks!
0 characters
1 Points
I have an RCA tv that the parental locks are set on and now the remote wont turn the tv on
you probably need to go for a universal remote , and check as the problem might be on the existing remote may not be working and then using the universal remote , u can undo the changes you have done .
Dec 14, 2014 | RCA 27" Tv Sdtv Universal R.c. connections...
I have a Viox 19" flat screen
The remote has probably failed, inspect the battery terminals carefully, if no change! there may be bad solder joints on the board, but you need someone to go deeper with this.
Apr 02, 2012 | Computer Monitors
I have a T220 Hd monitor/tv bought 2 years ago. From 2 days the remote control (nearly never used) doesn't work and every 2/3 minutes appares on the screen the menu to select the brightness the colurs...
the batteries of remote control may exhausted , replace it
the remote control working you may check through your mobile camera by following step
1. point the camera in front of your remote control's eye that is the LED
2. now press the remote control's any button and see in the mobile camera that LED is glowing or not
3. you may check other working remote of any other product which you have by this way i.e. through mobile camera
Aug 22, 2010 | Samsung T220HD LCD Monitor
Philips 190s turns itself on/off
Mine is a 190s Monitor and not a TV with any kind of remote unit controlling it. I had this issue about a year ago and it sorted it's self after a week or so left turned off. This makes me wonder if it has to do with heat and humidity affecting the micro switches located behind the push button controls on the removable screen surround.
Dec 01, 2009 | Philips 190S8FS 19 inch LCD Monitor
I bought my Philips Flat Screen TV Model No: 23PF9945/12 about 6 years ago. For the past 2-3 years, it's been switching itself off intermittently - sometimes 3-4 times a night! It's been in and out of the...
suziglantz, A good TECHNICIAN should be able to pinpoint where the problem is. I suspect that as long as the unit has perfect pic and sound when it IS ON, there should be no problem for a tech to find a thermally intermittant solder joint inside the unit on some printed circuit board. Most likely place to look first would be the Power Supply board. They are called "switch-mode-power-supplys" SMPS for short. Here is what I think. Parts are soldered to the printed circuit boards at the factory. But over time the unit is subjected to large changes in temperature. You do this every time you turn "on/OFF the unit. Let's see here, 360 days x 1 ON and one OFF x 6yrs will be approx 2000 cold to hot cycles. I would think that this would not happen for at least 4000 cycles. Again, a tech type person will need to find the poorly soldered component and or the SOLID STATE component which has a thermal intermittant problem. That's about all I can recomend at this time. Do some research on the web and you will find all types of info on temperature related failures of electronic devices. Please rate this response on fixya if you feel it has been of any help to you. I'm louie12fix on fixya or lmistyrel @ aol .com
Oct 06, 2009 | Philips 23PF9945-37 23" Flat Panel LCD...
I bought a used ACER H213H TV, it did not have a remote controller and the volume button on the TV is not working. I bought a universal controller but there is no acer code number what can I do
If you still have your instructions for the universal remote. Check in there and it should have a section for your tv or model not listed and how to do a search with your remote to find the tv. Then it will store it and you will be able to use the remote.
Sep 30, 2009 | Acer AL1917W LCD Monitor
Helpme please
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Aug 25, 2008 | Philips 150S4FB 15" LCD Monitor
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips/Magnavox 32MF605W/17 32" LCD Wide Screen HDTV ready w/ATSC.
Yes you can. This TV has both VGA-In and component in support. The only thing you need to change is the input you're using with your remote control. As easy as changing the channel!
Oct 15, 2007 | Philips Computer Monitors
Philips 107G66 / 17-Inch / 1280 x 1024 / Black / CRT Monitor Refurbished Logo
24 people viewed this question
Top Philips Computer Monitors Experts
 Mike M
Mike M
Lawrence Oravetz
olayoju victor
Are you a Philips Computer Monitor Expert? Answer questions, earn points and help others
