Thermostat is set too high, I would like to reset it to the factory default options or to a totally manual operation.
    Genius:
  • 1,847 Answers
Wht is the make and the model no#?
Posted on Oct 17, 2008
Need to reset the unit to the same temperature for all days and time for my Baeburn thermostate.
5.5 Resetting ThermostatThe Reset feature allows the user to completely reset the thermostat to register new manual
switch settings and return to factory set software settings.
1. To erase all entered settings, gently press RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation.
braeburn thermostat reset Google Search ref. link
Jan 02, 2018 | Heating & Cooling
How can I restore a Dell laptop to the factory default settings?
Here are the main steps to restore your Dell laptop to its factory settings. Depending on the model you own, the procedure may vary slightly.
Before beginning, please note that by restoring your computer to its default factory configuration, all data on the C drive will be deleted. We highly recommend backing up any personal files before moving forward with the reset.
Hard Reset Dell Laptop Restart your computer by clicking Start > arrow next to the Lock button > Restart.
As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
Note: You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Press the Down arrow to select the Repair Your Computer option on the Advanced Boot Options menu, and then press Enter. Select your language settings and then click Next.
Log in as an administrative user, and click OK. Then click the Dell Factory Image Restore option.
In the Dell Factory Image Restore window, click on Next. Check the box that reads Yes, reformat the hard drive and restore system software to factory conditions, followed by Next.
The computer will now restore to its default factory settings. Once the restore operation is completed, click on Finish to restart your computer.
Feb 27, 2017 | Dell Computers & Internet
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
I ned reset (lsu) for printer dell 1610n
[Clearing the Memory]
You can selectively clear information stored in your multi-function printer's memory.
Press <Menu> on the operator panel until "Maintenance" appears on the top line of the display. 1.
Press the scroll button ( or ) until you see "Clear Setting" on the bottom line and press <Select>. 2.
The first available menu item, "Paper Setting" displays on the bottom line.
Press the scroll button ( or ) until you see the item you want to clear.
Paper Setting: Restores all of the Paper Setting options to the factory default.
Copy Setup: Restores all of the Copy Setup options to the factory default.
Fax Setup: Restores all of the Fax Setup options to the factory default.
Fax Feature: Cancels all of the scheduled fax jobs in the printer's memory.
Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
All Settings: Clears all of the data stored in the memory and resets all of your settings to the
factory default.
Sent Report: Clears all records of your sent faxes.
RCV Report: Clears all records of your received faxes.
Phone Book: Clears the speed dial or group dial numbers stored in the memory.
3.
Press <Select>. The selected memory is cleared and the display asks you to continue clearing the next
item.
4.
Repeat steps 2 and 3 to clear another item. 5.
OR
To return to Standby mode, press <Return>.
[Page 130]
Dell Laser Multi-Function Printer 1600n User's Guide
ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-1600n_User's%20Guide_en-us.pdf
Jun 12, 2014 | Dell 1600n All-In-One Laser Printer
Need to reset the default language to spanish
That totally depends on the Operating System installed by the manufacturer.
Check on their website.
As a general default, going to main menu / settings there will be an option to Reset to Factory Default. This generally then forces you to reconnect to your wi-fi provider and reset tablet languages.
(This is a pure guess for your tablet, sorry, no makers name so no real clue.
Jan 21, 2014 | Polaroid Tablets & eReaders
Hi.my phone model is nokia 5233 and v21.1 & Rm 625. some days age i am port my phone nokia 5236 & v40.9 .after that when i use internet them restart my phone automatic with 30 menute.how can i...
Have you tried to manual reset your cellphone? Warning! It will reset all your users settings and also will erase your files and contacts saved in your phone memory.
Restore the original factory settings
Restore original settings
Select Menu > Settings and Phone > Phone mgmt. >
Factory settings.
You can reset some of the settings to their original values. To
do this, you need the lock code.
After resetting, the device may take a longer time to power
on. Documents and files are unaffected.
Nokia 5233 hard reset with buttons / keys
Press and hold GREEN + RED + CAMERA when powering up, then
input default 12345 security code.
You can also try this Total Reset or Hard Reset for nokia 5233
This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile
Jun 07, 2011 | Cell Phones
If I take out the battery on my skylink sc-100 does it reset it back to factory settings.
I guess the question is about the control panel SC-001.
If power is totally removed (disconnecting DC jack and removing battery) from the control panel, user settings will be restored to factory default. These include all passwords and zone settings. Master PIN will be reset to "000" and secondary PINs will be deleted. Home, Away, and Night sequence default zone setting can be found in the manual.
However, all programmed sensors and remote controls will remain intact. This means that all programmed sensors would still trigger the control panel if activated. And programmed remotes would still operate the control panel. To remove installed sensors or remotes, simply disconnecting power will not work. User must follow instructions in the manual to remove sensors or remotes from a zone.
Feb 19, 2011 | Skylink Group Skylink Sc-100 Security...
How to i get my amd turion 64 x2 tl-50 to factory reset?
You can reset your BIOS to factory default. There is an option there. Or you may only change the settings about CPU to the default or automatic.
Aug 18, 2010 | AMD Turion 64 X2 TL-50
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
K850i,contrct from 3 ended got phone unlocked put in new sim to start new contrct, every thing works but txt . wont send or recieve ???? new network says my phone is bust tried new sim in other phone and...
This is a unusual symptom in a mobile phone, you should try a hard reset and a factory reset.
1. Hard reset, take the battery out for 30mins and try again
2. Factory reset will reset your phone to factory default settings to so this just go in the settings option and then find the reset option make sure you choose the total reset option
Hope this helps
Muzzi_123
Nov 14, 2009 | Sony Ericsson K800i Cellular Phone
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
