Question about Alesis Monitor One Mk2 Speaker
Mk2 speakers Wont come on with power. Light not on. Matching speaker works ok
  • Anonymous Dec 24, 2008
    Same exact problem as the other guy - one of the speakers just stopped turning on without any previous problems.
    I opened up the speaker and switched the fuse from the one that didn't work with the one that did, and it didn't change anything.  It's not the fuse.
    Also, my friend who is good with electronics said that the transformer was getting power, even though the speaker itself wasn't working.
    Problem Solver:
  • 4 Answers
Is it the m1 active mk2???if so try changing the fuse in the power supply..i know my ones the light started to flash on one,i switch it off with a fan on it for 20 mins and it works again..so i just leave it on now.
Posted on Nov 27, 2008
I lost the treble on both Alesis Monitor 1 speakers. The treble is good on the amp output toward the speakers. I'm thinking they went out one at a time and I didn't realize it until I lost the...
It's probably blown tweeters. But if you want to spend the money on a hipshot guess, try to find the the crossovers somewhere first; then find the readily available tweeters if/when that doesn't work out. Google "alesis monitor one MK2 tweeter".
You could test the tweeters by just removing one non-functional tweeter and wiring it directly to the speaker leads and with REALLY LOW volume containing NO BASS see if it makes any sound, which would prove it does/does not work.
Going forward, if the speakers sound stressed at high volume - THEY ARE. Too much power or too much distortion (overdriven amplifier) will kill speakers.
Sep 16, 2011 | Alesis Monitor One Mk2 Speaker
I dont kno the wiring colors for my 2000 taurus radio
All you need to do is get the power, ground, and antenna hooked up then start with two colors matching, example: one purple and one black with purple line hook those up to a matching speaker wire then turn stereo on and go to balance setting choose back left if speaker does not sound then go back right and if speaker does not sound then try front speaker right and then left once you find correct speaker move on to next two matching remember to. Mark wires FL or fr or bl or back right. Good luck
Sep 10, 2011 | 2000 Ford Taurus
Im using my vestax vci 100 mk2 with my macs built in speakers.i am only able to hear the sound ouy of my headphones and if i choose built in speakers as an option in the set up wizard i can only hear the...
It is an either/or thing. I would recommend you get a headphone amplifier or get external speakers and drive them externally. Internal speakers are relatively poor quality anyway
Apr 28, 2011 | Vestax Vci 100 Midi Controller
How do i go about connecting the alesis monitor one mk2's to my my laptop? i do not have an amp and there are no cables or connectors with the speakers when they arrive
You can without an amp in between. They are non-powered speakers and need an amp to drive them. If you connect your laptop to a mixer, mixer to an amp, then amp to speakers THEN they will work.
Feb 19, 2011 | Alesis Monitor One Mk2 Speaker
When ii turn the speakers on the blue light just keep flickeriing band no sounds is coming through
Check all connections and also make sure the polarity of your speakers are correct,(+ to + , - to -), look to see if you have used the speaker output for sound also. Sometimes the plugs look the same but go to different outputs.
Oct 06, 2010 | Alesis Monitor One Mk2 Speaker
Ok my Dual speaker box has lights but they wont turn on
Sounds like the transformer is bad. They are either on the ends of the tubes or located in the sub chamber. follow the + and - to the transformer(s).
Hope this sheds some light on it!!!
Oct 21, 2009 | Car Audio & Video
One speaker fell ... no sounds ?? can it be
Most likely, if the LED is still functioning on the speaker, then an internal connection has simply come loose. If you use a screwdriver to remove the woofer (the large speaker) you will gain access to the inside. You should be able to both easily see the loose connection and reach it to plug it back in.
A little less likely, but also possible is that a part of the internal circuitry is broken. But, usually in those cases, the light stops working as well.
I hope this helps.
Oct 08, 2009 | Alesis Monitor One Mk2 Speaker
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
Alesis m1 mk2 active emits low pitch hum and does not work
You need to take a closer look really, see if anything on the power supply board inside has melted, burned, popped, etc.
Mar 13, 2009 | Alesis M1-Active MkII Main / Stereo...
1995 grand prix
do you have a test light?your speaker wires should be four sets of matching color,dark/light blue,dark/light green,dark/light purple and one other matching set of colors. then there should be one black wire which should be ground.with a test light you can find your power and accesory wires. your power wire will always have power with key on or off,the acc wire will only have power when key on. i hope this will help.
Aug 04, 2008 | 1995 Pontiac Grand Prix
Alesis Monitor One Mk2 Speaker Logo
424 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
sonic boom...
sonic boom...
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
