Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto Sirius S Class
After I changed the water filter and then went through the cleaning cycle, the coffee machine suddenly turned off by itself; completely blank. I checked my electrical plugs but everything is fine there. What I noticed was a burned smell while I was ventilating the machine. Anyone knows what might have happened? Did something burn inside? Please help!
  • 515 Answers
Take off the top of the machine, look at the printed circuit card and see if you can see anything that is broken.
Look at the fuse in the machine to see if they need to be reset.
Best regards
/Mirran
Posted on Oct 27, 2008
Saeco incanto Sirius led screen flashing
Electronic parts don't like water - propably you have to change LED which is iluminating tej panel
Jan 06, 2012 | Saeco 00034 Incanto Sirius Super Automatic...
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
Saeco S-class Incanto Sirius brew unit stuck
Try running the clean cycle again, that sometimes will help the machine to reset.
Sep 15, 2009 | Saeco Incanto Sirius Fully Automatic...
My saeco s-class incanto sirius machine keeps say replace water filter & ventilate even after I replaced filter
Sounds to me that water is not getting to the pump. Try charging the water filter before using by letting it sit in some water for about 5 mins.
Jul 23, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Water is leaking
Replace the tap rod assembly or the complete steam valve.
Feb 22, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Need parts for Incanto S-class (door unit)
Go to this site and find a Saeco Service Center near you.
http://www.saeco.com/countrygate/
There are two number on this spare part if it is the spare part in the machine, if it is that on the door you only have one number.
Best regards
/Mirran
Nov 08, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco incanto sirius
It can be the touch board or the "water turbine" in the machine
May 25, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Classic Espresso Machine Logo
285 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
