Question about Connex 4600 Base CB Radio
Squealing Noise When keying mic just get squealing noise. Have tried many things and nothing seems to resolve the problem. Any ideas?
  • mac10guy Nov 17, 2008
    i have the same problum. i have a galaxy dx949 with talkback.
    when i key up with one mic i dont hear my talk back and i cant use my pa and i come out REALLY quiet.
    when i use another mic and i key up my pa works fine but my talkback makes a terrible screeching sound. though my voice does trasmit so does the screech.
    Problem Solver:
  • 14 Answers
Some radios use the push to talk switch in the microphone to ground the receiver section when transmitting instead of a relay in the radio. There may be a problem with that switch, or the switching circuit in the radio itself.
If you have a PA switch make sure it is in the off position, if on it will squeal like a pig!
Posted on Nov 05, 2008
  • h_jules Nov 05, 2008
    Also check the mic cord for breaks or shorts.
Bear tracker squealing noise when trying to start after running it goes away help please it sat for a year before got rear end fixed
Joe, do you mean a bearing track?
If so, a bearing -or track - usually makes a grinding or knocking noise, not a squealing noise.
If a car stands for a long time the brake rotors can corrode a bit and the pads can stick. Sometimes, when the car is first used after standing, you may hear a rubbing or squealing noise from the wheel. That's the pads sticking to a rusty rotor. The noise may wear off after a few miles when the pads 'polish' the corrosion off the rotor.
The other thing that causes squealing from a wheel are the brake shims. Try cleaning things first.
Mar 14, 2016 | Cars & Trucks
How to remove cover from 2008 jetta 2.5 engine
To resolve the squealing noise two things come to mind. Take an old bar of soap and hold it in a SAFE area with the belt turning which acts like a lubricant without the grease. If the belt is cracked the soap will fill in the areas and reduce or eliminate the noise. If that does not fix it you may have a loose or cracked pulley.
May 18, 2014 | 2008 Volkswagen Jetta Wagon
I have a loud squealing noise upon starting the car. the squealing normally lasts about 30-45 seconds. sometimes the noise will appear aftrer pulling off from a stopped position, as well. all belts
Try to tighten the belts a little firm.Sounds like when engine idling no squelling only when about to take off .Some times belts may seem ok on the outside but if you look on inner side you tend to see cracks in the belts .
Jan 06, 2014 | 2000 Mazda 626
Rear squealing noise when accelerating.
nothing to do with breaks sounds more like a u joint or bearing
Nov 25, 2012 | 2003 Toyota RAV4
How can i disconnect the talk back on a connex 3300 plus? pleasa be specific on directions. thanks
in older connex 3300's you cannot disable the talk back. Its part of the audio chain. If you disable the talk back you will loose your audio. There are 2 things you can do.
Hook a relay to the speaker so that when the radio key's id disconnects the speaker. (Big pain, not worth the trouble.)
The other will not disable the talk back but it will stop any squealing.
Use a noise canceling mic. An RK-56 will work great. You will get no squealing with that mic.
Oct 19, 2010 | Connex 3300 240-Channels Base CB Radio
Belt squealing noise when heater turned on
yes...your engine belt is little bit lose that's y its causing noise...and hope when u speed up..it will stop squealing ..right?? so just tight your engine belt little bit and it will solve your problem in a min...take care n have a safe journey...n also if it help...rate it plz
Jan 23, 2010 | 2001 Hyundai Elantra
High pitched squealing and now not working
Seems like the wii froze. Try other discs and if worse comes to worse send the wii to nintendo
Dec 31, 2008 | Nintendo Wii Console
Squealing noise
The pump motor is beginning to seize up. You may be able to take the dishwasher apart and lubricate the bearings and keep it going for a while, but at some point you will likely have to replace the pump motor assembly.
Jul 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Radio Communications Logo
572 people viewed this question
Top Connex Radio Communications Experts
Steve
Tony
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
