Question about Estate TGDX640JQ Gas Dryer
No puilot on.
I have an Estate TGDX640PQ1 gas dryer (whirlpool) and when I put the clothes in it, and started her up a could smell gas. Where in the dryer can I find the glo plug?
U must rmove the whole front of the dryer to get to the pilot. Good luck.
Posted on Jul 13, 2009
Dryer slow to start. push button several times to get started. pulls heavily on electricity and causes 120 surge protectors to pop. any ideas?
are you overloading it with alot of wet cloths , you cannot put a ton of cloths in a dryer , try this first , make sure the filter is clean out ,and even the exaust pipe is not clogged either
Mar 07, 2015 | Estate by Whirlpool EED4400WQ Estate 29in...
Dryer smells like fire has wiring
Replace the high limit thermostat.The high limit safety thermostat is a back-up thermostat that will shut off the heating element if it detects a temperature above 200 degrees. The thermistor (temperature sensor) that is on the blower housing detects the temperature in the dryer. It is the component that helps the control regulate the operating temperature at around 150 degrees.
Here is a link to the part you need.
Here is a video to show you how to replace the thermostat.
Oct 14, 2012 | Estate by Whirlpool EGD4400WQ Estate 29in...
When drying clothes in my gas dryer, you can smell gas upon opening the door. If the dryer is not running, you do not smell a gas odor. Sometimes our clothes also have a gas smell.This just started a week...
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Jan 17, 2010 | Estate TGDS740JQ Gas Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
We have an Estate Whirlpool clothes dryer/Model #MY60-G which was purchased (I think sometime in 2002?). It spins, but after it is on for a little while the heat stops and the clothes never dry. We were...
gas dryer ? replace the 2 coils on gas burner the 2 black round dohickys..electric possible bad operating thermostat remove back round object on blower housing
Jul 08, 2008 | Whirlpool Dryers
Spins but no heat
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE;
Apr 11, 2008 | Whirlpool LGR7646E Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Estate TGDX640JQ Gas Dryer Logo
161 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Mike
Are you an Estate Dryer Expert? Answer questions, earn points and help others
