Question about Hotpoint RGB745 Gas Kitchen Range
Broil works but Bake does not
My Hotpoint RGB745 broils fine and the burners work, but the bake just stopped working. With the broil on, the glow plug current is approximately 3.3 amps, with bake on, zero. I checked the relays. From the back of the panel, L1 to N 120V, N to Broil 120V when broil selected, N to bake 120V when bake selected. At the gas safety valve, 120V when broil selected, 18V when bake is selected. Any ideas?
  • 2 more comments
  • cywanker Oct 17, 2008
    Ah-ha -- there is another glow plug underneath that lights the burner for the oven...
    Simple fix...
  • NotMsFixIt Oct 25, 2008
    I'm dumb - what did you do to solve it?
  • lisa7477 Nov 11, 2008
    I have the same oven, and the bake just stopped working. Is there a pilot light that I can light? Or do I need something else?
  • Anonymous Mar 26, 2014
    Preheats only
    Sergeant:
    Champion:
  • 324 Answers
Change the bake ignitor?
Posted on Nov 05, 2008
Hotpoint propane model rgb746hed2wh oven burner will not turn off, Digital reading f-2
F2
During BAKE, Control senses oven temperature above 615F-630F
f actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC). Here is the part to order.
Dec 16, 2013 | Hotpoint RGB745 Gas Kitchen Range
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Oven will not work but broil will work
If this is a gas oven the most likely part to fail would be the bake igintor,
If you look side when you turn it on you should see it glowing orange near the burner.
If you have an electric oven the most common part would be the bake element. There are two separate elements for cooking, one bake and one for broil
May 23, 2010 | Frigidaire Ovens
Hotpoint oven and broiler won't turn on
Since both broil and bake do not work you must replace the ERC (clock).Part number WB12K0020 about $150.00.
Apr 01, 2009 | Hotpoint RGB745 Gas Kitchen Range
Burners work,Broiler works but oven does not preheat
If everything works on your range, but the oven, the most likely culprit is the igniter for the BAKE manifold. What is confusing me, though is the statement in your question where you say the "oven will light up, but never get hot". Yet, you say the oven does not ignite. Can you clarify this? In some ovens the BAKE and BROIL manifolds BOTH light when preheating, to reduce the warm up time. Once the desired temperature is reached the manifold not in use, will shut off.
In any case, on a gas range, the burners for the BAKE and BROIL manifolds use an electric glow bar type igniter. There's a separate igniter for EACH burner. When you make a bake or broil selection on your oven control, the respective igniter begins to glow. After the igniter reaches a certain current potential, the gas safety valve is opened, gas flows to the manifold, and voila! You have ignition. It can take as long as 90 seconds for the burner to ignite. What can happen over time, is the igniter becomes weak or fails. If the igniter becomes weak, it will still glow, but it never reaches the desired current potential to open the gas safety valve. The result: you end up with an igniter glowing with no ignition. And, if you're like me, you're left scratching your head wondering why the thing isn't working when it "looks" like it is. You can easily tell if the igniter is working by opening your oven door and selecting bake. Watch the oven pan in the bottom of the oven. You should see an orange glow coming from under it. It here's no glow at all, the igniter has probably failed. If there IS a glow, a current reading will tell if it's within tolerance. The following link explains more on these igniters and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter is a common fail item as it gets used more frequently than the broil function. On your range both igniters are interchangeable. You can purchase replacements on line at searspartsdirect.com, repairclinic.com, or appliancepartspros.com. The part number is WB2X9154. Shop all three sites for the best price.
I hope this helps you. If my assessment of your symptoms is wrong, or if you need further assistance, please let me know.
Jan 15, 2009 | Hotpoint RGB745 Gas Kitchen Range
Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Sep 28, 2008 | Whirlpool GY396 Electric Kitchen Range
Bake burner
It is almost always a weak bake igniter. These age and will no longer pull enough current through them to allow gas valve to open. If bake igniter comes on and doesn't light, replace it.
Nov 17, 2007 | Ovens
Hotpoint RGB745 Gas Kitchen Range Logo
660 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
