Question about Nintendo Wii Console
Will not read disks
Our Wii will not read disks, we can put them in and it will not read any of the disks we have. We haven't had it that long. I have done all the suggestions from the owners manual. HELP!
  • 30 Answers
You may try a CD/DVD OptiDisc Laser Lens Cleaner by Memorex. Hope it helps!
Posted on Oct 17, 2008
  • 32 Answers
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Mar 04, 2009
I have the same problem i try two diferent disc y nothing happen. same error . i dont think is my wii console.
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. I like to use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, which pack more info onto a disk (Super Smash Bros. Brawl and Metroid Prime use dual layer discs). If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. If all fails and still you Wii cant read any disk it only means that the Wii is malfunctioning.
Thanks for Reading. Thanks for using Fixya.
Feb 06, 2011 | Nintendo Super Smash Bros. Brawl for Wii
My wii fit plus disc reads cant be read when inserted in to the wii help please can it be fixed
Hi lyned1,
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
Jan 28, 2011 | Video Game Consoles & Games
Wii wont read discs
put in a cleaning disk.
Jul 16, 2010 | Nintendo Wii Console
Disk won't work
Did you put it in correctly? If the Wii is facing vertically, the side with print on it goes AWAY from the buttons. Anytime you put in a Wii disk in, the print side must go away from the buttons. Hope this helps :)
Jan 03, 2010 | Nintendo Wii Console
WII will not read disk
Aug 07, 2008 | Nintendo Wii Console
I put a disk into my Wii and it comes up with a question mark and says the disk is unreadable. It does the same for any disk that I put into it. I have done all the recommendations in the manual including...
it appears that your laser unit is faulty. And not reading the games. Try a music CD or other type of supported media ( Disk )
if it reads nothing at all. Suspected laser read Failure.
Mike @ Compurepair.
Jul 19, 2008 | Nintendo Video Game Consoles & Games
Unable to read disc message
Could be a damaged disk (check closely), a bad disk (did it work before) or your lens could be going out (which makes it unable to read the disk). Have you tried putting another disk in to see if you get the same problem?
Jul 19, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
176 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
