Question about Teac MP-111 MP3 Player
RCA Pearl TH1602 Frozen?
It doesnt load, all it does is show the PEARL logo when i turn it on and then it stays like that. I've tried replacing batteries, and tried putting the device into my computer but neither the Device or computer tell me it is connected to the usb port.
  • 1 more comment
  • Anonymous Nov 05, 2008
    same
  • fugcandy Nov 07, 2008
    When I turn the pearl on it just displays the "pearl" logo. It's like the MP3 player is frozen.
  • Anonymous Dec 28, 2008
    Mine is also in this frozen state. If I take out the battery, put it back in, and leave it off, my computer will still recognize it through the USB port. I can load/unload songs, but when I power it back up, it goes to the frozen "pearl" screen again. This mp3 player has more problems than I care to list past that. As for support, the RCA site only lists how to install it with Vista, and I can't find any other outlet for help. Thanks RCA. Anyone who actually cares about other people out there that can help?
  • 4 Answers
My solution to a Pearl TH1602-A stuck on the pearl screen:
Download the firmware upgrade from Lucy5829's solution, run it.
RCA PEARL FIRMWARE DOWNLOAD window should open.
Remove battery from Pearl, keep out.
Press PLAY and hold while plugging into USB port,
when "initializing" progress bar moves, let go off play button.
On my windows, it installed some software and asked me to reboot. After the reboot I re-ran the Pearl firmware file and about 30 seconds later the start button was now available.
Click it. However, You will loose your music on the internal storage.
Posted on Oct 23, 2009
I had the same problem, usually plugging it into the usb port on the pc and verifying the files on the player, then disconnecting the player will solve the problem. Other times i have to reformat the player, if you do that, you will have to put all your music back on. It's a pain, this has happened to me 4 times, I've only had this thing less than 6 months! It was inexpensive, I guess you get what you pay for, but I like having a AAA battery instead of having to remember to plug it in to the pc to recharge every 15 hrs.
Posted on Feb 07, 2009
I Had the same problem - just displayed the pearl logo but worked fine as a usb key. I tried reformating and put everything back and had the same problem. I updated the bios by using the easyrip software and now it works again.
Posted on Jul 09, 2010
2 Suggested Answers
  • 133 Answers
SOURCE: rca pearl th1602-a with new battery will not power
When was the last time you flashed the firmware? Even if it already has the latest firmware, it sounds like it is still corrupted and need to be reflashed. It appears you already know where to find the latest firmware update based on your comments, but just in case you can download it here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2557
RCA pearl th1602-a with new battery will not power on. Old battery will power on, but freeze at pearl logo. Player dosn't power on when plugged into USB of computer
Try a firmware recover. Download the firmware update from the RCA website and install the app. Start the updater and connect the player holding the PLAY button until it gets detected.
This is a similar player with the recovery procedure explained:
Oct 28, 2009 | RCA TH1602 MP3 Player
Tip
How to Fix Your RCA Pearl TH1602 MP3 Player from Freezing at Startup
Does your RCA Pearl TH1062 MP3 player freeze on startup at the Pearl logo?
Whenever your player acts up, the best solution is to reflash/upgrade the firmware.
Download the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and follow all the troubleshooting instructions that popup when you start the program:
  1. start the program,
  2. remove the battery,
  3. hold the play button while plugging the RCA player into your computer's usb port,
  4. release the play button when the term "initalizing" replaces "searching",
  5. check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
  6. click the start button to replace the firmware.
This solution will fix your player.
I hope that helps.
on Jan 17, 2010 | RCA TH1602 MP3 Player
RCA pearl th1602-a with new battery will not power on. Old battery will power on, but freeze at pearl logo. Player powers on when plugged into USB of computer. It is already at the latest firmware.
Oct 22, 2009 | RCA TH1602 MP3 Player
Rca pearl th1602-a I turn it on all I get is the pearl emblem and it wont turn off. I have to pull the battery to stop.
Download the firmware upgrade from RCA's website, run it.
Oct 07, 2009 | Audio Players & Recorders
After pressing the "MENU" button to turn on my RCA Th1602-A the "PEARL" text and logo appear for about five seconds and then it returns to being. The battery is good. It operated perfectly during the...
The other day I replaced my battery and my unit would not go any further than the Pearl logo. So I downloaded the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and followed all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button when the the term "initializing" replaces "searching",
You might want to leave the "format data" box unchecked to see it that works. I couldn't play aac files without formatting, but you may not have to format to fix your problem.
After I did this, my pearl started normally, and my computer recognized it again.
Aug 18, 2009 | RCA TH1602 MP3 Player
I have a rca pearl th1602 and everytime i turn it on all it does is say pearl and wont do anything else. how do i fix this or what is wrong with it?
start the program,
remove the battery,
Jul 06, 2009 | RCA TH1602 MP3 Player
Frozen at the opening screen, can't be detected by the computer
Actually, the firmware software will fix your Pearl even though the computer won't detect it right now. It worked for me and I've fixed my sony phone the same way. Try grabbing the latest firmware here:
And make sure you follow all the directions that popup, including removing the battery, holding play when you plug it in, and formatting the data area.
Mar 05, 2009 | RCA TH1602 MP3 Player
RCA TH1602 MP3 Player in locked
You should be able to force the Pearl into recovery mode by removing the battery, then hold down the "Play" button while inserting into USB port, after a few seconds, Windows should detect "USB Human Interface Device" (see Device Manager). Now you should be able run the firmware update. Worked for mine after it froze up one day and would not be detected as a USB device by Windows.
Nov 14, 2008 | RCA TH1602 MP3 Player
Teac MP-111 MP3 Player Logo
1,524 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
