Question about Apple Studio (White) 17" LCD Monitor
Monitor flickers occasionally then cuts off
While using my apple studio 17" display for more than an hour, it sporatically flickers off and on and then cuts out completely. after shutting down and leaving off over nite, it does the same thing. seems to get worse the longer i use it. there is no pattern or specific length of time of using before this occurs. it's connected to a dual 1 GHz PowerPC G4. the display is approx 4 years old. it's been sitting on the same desk/plugged into the same outlets it's whole life, nothing has changed/been added etc. any suggestions will be appreciated. thank you!
  • Carmelita Nov 08, 2007
    My problem is the same as Aprils. However the monitor makes a popping and crackling sound and the screen shrinks. Any help would be appreciated. Thank you
Well...it is still sitting here unusable! took it to the imac store and they said it could be fixed for a flat rate of $400 - but could buy a new one for that price...so to answer your question, i never got it fixed or figured out the problem! thanks for your reply though april
Posted on May 31, 2007
Hi April! I don't have a solution to your problem, but I do now have exactly the same problem (and G4/display) ! I wonder if you ever managed to get it fixed? Another posting suggests the LCD inverter may be to blame. Did you investigate this at all? Best wishes Tristram
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
I AM TRYING TO CONNECT MY APPLE STUDIO DISPLAY TO MY MACBOOK PRO AND DONT KNOW HOW OR WHAT CONNECTOR I NEED
Your Studio Display uses an ADC connector, which is very much like DVI but also supplies power for the monitor and adds USB pins so that you can use the USB on the monitor. In order to use it with something that has DVI instead of ADC, you need this adapter from Apple; there are a couple places that have it $5-10 cheaper, but you may as well get it from the people who made it, Apple probably has a better return policy than anyone else in a situation like this. You hook this adapter into the wall and into your laptop, and hook the monitor into the adapter. Hope this helps!
Nov 06, 2009 | Apple Studio Display 17" LCD Monitor
Will not power up
You have plugged the display into a wall socket as well as the DVI connector to the MBAir and turned that on right? J
Aug 13, 2017 | Apple Studio Display 17" LCD Monitor
Need Repair Manual for Apple Cinema Display M8149
here is a manual for the 17 in. apple studio http://www.devicemanuals.com/guide/Display%20and%20Video/Apple/Apple-Apple-Studio-Display-(17-inch-CRT)-User%27s-TVRBek9BPT.html
Jun 30, 2009 | Apple Studio 17" Flat Panel LCD Monitor
How do I connect my apple model m7649 monitor to a dell laptop? Thanks to anyone, ron
you should be able to get hold of a convert that plugs in to your laptop then you should be able to plug the monitor in to the converter with out having any problems with display settings
hope the information is abit of help to you
Mar 04, 2009 | IBM (14R0060) Monitor
Will new MacBook work with 17 inch Apple Studio Display?
If you own just a Macbook this is what you need http://store.apple.com/us/product/M8661LL/B#overview
If you own a Macbook Pro http://store.apple.com/us/product/MB570Z/A
Make sure you do the full research on these things, so that you don't spend money on the wrong thing, adapter and connectors can be somewhat confusing.
Dec 11, 2008 | Apple Studio Display 17" LCD Monitor
Apple monitor
I THINK YOUR DISPLAY COLOR PROBLEM.
DEGAUSS YOUR DISPLAY, CHANGE YOUR DISPLAY COLOR RESET IT TO DEFAULT SETTINGS.
Mar 24, 2008 | Apple Studio Display 17" LCD Monitor
Connecting Apple Studio Display 17 ( LCD ) to Apple G4 Cube
Check the connector coming from the monitor and see if any pins are crushed or touching. It may be shorting power going to it.
Mar 02, 2008 | Apple Studio Display 17" LCD Monitor
Studio display m7649 picture will not come up when connected to toshiba laptop
I am not sure how youve manage to connect these 2 items. You did not specify whic Portage you have, but even the most recent only has SXGA video port. The Apple cinema display connector is ADC. APPLE DISPLAY CONNECTOR. No computers on the planet have this port except for apple's. It's basically a modified DVI connector. In order for you to use this monitor with your computer, you would have to purchase a DVI to ADC connector , which is another APPLE only item and selld for $100 new. You would then have to purchase a SXGA to DVI adaptor...It sounds like a costly endeavor, and with a connections your Portage's onboard video card , amynot even support the resolution for this monitor.
Hope this helps.
Oct 17, 2007 | Apple Studio Display 17" LCD Monitor
Apple Studio (White) 17" LCD Monitor Logo
175 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
