Question about HP Office Equipment & Supplies
Print fades when printing even though it says there is black ink
  • Anonymous Jan 27, 2009
    black print fades
    Problem Solver:
  • 22 Answers
Is this laser or Ink Jet? Have you tried running a cleaning cycle?
Posted on Oct 17, 2008
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Apr 07, 2010 | HP Deskjet 3845 InkJet Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer won't complete the cartridge alignment function. It only prints the first two bars and then stops. When printing the black cartridge looks faded and half printed lines across even though it is a...
My printer does the same thing. I changed the blank ink yesterday (the printer shows the black ink was low) however after trying and trying and not being able to complete the alignment I decided to change the color ink as well.
It worked. Printer works fine now. Sometimes the ink dries up and you have to change it even though you know it should last longer.
Give it a try and let me know.
laura@theprincessandthepup.com
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
My printer won't print black ink even though the cartridge is full
try to clean the nossles with software from the manafactures website
May 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
OKI C5200 - Faded black print area
Trying cleaning the black LED's that are on the top portion of the open clamshell. Use rubbing alcohol on a rag and wipe each bar x4/. These units charge the drum surface where print is going. This should work.
Jun 12, 2008 | Samsung OKIDATA - OKI C5200n - Printer
Faded print job
ok...have you tried a clean and re calibrate lately on those print heads?
Mar 20, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
182 people viewed this question
Ben Johnson
