Question about TurboChef TORNADO Electric Oven
How did you fix your F3 Mag Cur code?
I have the same problem - just started happening tonight. How did you fix it?
Thanks - NIck Yager
nyager2@aol.com
    Champion:
  • 254 Answers
There are 2 mags in this oven yo have to figure out which mag is bad and replace it. This can be tricky and dangerous since there is a 4800 volt cap you will have to disconnect.
Posted on Nov 15, 2008
Display shows food done within 2-3 seconds. cycle is programmed for 15 seconds heating What is causing the problem
That typically means the microwave circuit is not powering on so the oven turns itself off. Most of the time when that happens you will get an error code flashing on the bottom of the screen. If F3 MAG CURR. Look at my previous answers on fixing that
Oct 11, 2015 | TurboChef C3 Single Oven
I was using my oven to bake something ---when suddenly I heard a beep and saw the code F3 E2. I turned the oven off for a bit then turn it back on. the same thing happened. What does it mean. I have...
Sorry, it looks like your baking (in this oven, anyway) is over for tonight.
For Whirlpool ovens, F3 means that the main control circuit board is reading a temperature that is too high. The E2 code indicates that the temperature sensor has probably failed and needs to be replaced. It's a fairly easy fix for a service person, but you are probably not going to get the parts and/or technician before tomorrow.
Wish I had better news for you. Hopefully, it's under warranty!
Jul 15, 2011 | Ovens
Hi, F3 mag curr. what is means and how do I fix it?
F3 is an complex code.
Easy fix is look at the transformers and the capacitors and the diodes.If it seems that any component has changed its appearence then fix it and replace the F3 fuse(3rd one from the front).
If the magnetron is bad ,then to check that you must know how to use clamp ammeter.
let me know if you know how to use clamp meter .
I will give you the solution .
NOTE oven has 5000V in it.
make sure you dischared the capacitors.
Thanks
please rate my work
Apr 16, 2011 | TurboChef TORNADO Electric Oven
I have a c3 oven that has a fault code f3 mag curr
Very expensive mag required , buy tornado or i3 instead don't waste your money on c3
Jan 03, 2011 | TurboChef C3 Single Oven
TURBOCHEF TORNADO OVEN...Errors F3 Mag Current and F5 Mag Temp just began. They appear occasionally, now and then. Oven temp seems about right to me. What needs replacing or attention? Thanks!
the mag's only activate while in cook cycle, it will be hot as normal with toasted subs that are cold in the center.
AMP draw the Mag's and ohm the Mag thermal couples
Oct 14, 2010 | TurboChef TORNADO Electric Oven
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
F3 Mag Curr. on Turbochef Tornado
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone.
Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
or 1800 90turbo
Hope that helps, and thank you.
Dec 21, 2008 | TurboChef TORNADO Electric Oven
F3 MAG Error
open the right side panel and change 3rd fuse from the left
Oct 18, 2008 | TurboChef TORNADO Electric Oven
Error code f 03 has come up on our oven
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Nov 05, 2007 | Blodgett DFG-100 Gas Single Oven
F3 Error Code
Oct 12, 2007 | Ovens
TurboChef TORNADO Electric Oven Logo
1,410 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
