Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Water gets to filter but not anywhere else
I have water to the filter but when you push for chilled water it just comes out top of filter to leak into fridge. Will not make ice if you leave icemaker on it will just leak into fridge. The fridge has been in storage for a year and worked fine whe put in there. I changed filter and still no luck. Any ideas?
Your water line that goes past the filter is clogged. use compressed air to flush out
Posted on Oct 21, 2008
Can I bypass the filter entirely the water is already filtered and have the incoming waterline go direct into the Dual Inlet Water Valve?
the purpose of the line running up and down again is provide the chilled water (as evidenced by "dual water valve) there is nothing saying that even if the original line is encased in the foam insulation , the new one cant run up the outside of the back case , its just not going to be chilled any longer , but would eliminate the leak in the line that's internal (inside foam) you will have to come up with your own type of tube connectors as I do remember that the factory ones use crimped clamps , and no they cant be reused again if removed
Nov 06, 2015 | GE Refrigerators
Water leaking from hose on water filter housing
shut water off to ref and try cutting the end of the tube off, but only 1/8 to 1/4 of an inch.. insert back into housing firmly and turn water back on and see if leak stopped.... if still leaking order and replace the filter housing..... hope this helps....... ken
Oct 09, 2014 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Water leaking from water filter housing
if water is leaking from where water line is try cutting the very end off water line and reinstall water line... if it is leaking any where else replace housing
GE refrigerator chilled water has mildew taste
change the water filter usually located in the upper right hand corner of the refrigerator compartment on side x sides,if top mount freezer it can be about anywhere inside the unit except freezer compartment
May 11, 2012 | GE Refrigerators
I'm getting a leak from the top of my water filter
Dodgy push fit connector? depress the end, pull out hose from filter, cut off 10mm off the end, add some ptfe tape to end, push back in fully and pull gently back to make sure it's tight
May 06, 2012 | Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leaking from bottom and hose not connected
The hose just pushes on. You will have to take the top cover off to rehook up the hoses. There are scres on the bottom, then where the dirty water tank sits, there tabs that you have to unhook, then the cover will come off. Note: the filter inside the ditry water tank, leave a gap at the top to the filter. If you push the filter all the way up, it won't spray or suck up.
Jan 05, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
No water coming out of water filter
check to see if the filter is in backwards! most inline filters flow only one way!
Dec 18, 2007 | Kitchen Appliances - Others
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
129 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
