Question about SanDisk Sansa e260 MP3 Player
SanDisk, 2 GB Sansa mp3 player won't charge
I plugged it into my puter with the cord that came with it, does not charge that way. it did charge when plugged into my son's stereo--once, but now is completely dead----how do I fix it? what do I do? I plug my Sandisk Sansa 4GB mp3 player into the computer with the cord that came with it, and it wouldn't charge. I once plugged it in on a wall charger, and it charged once. Now it is completely dead and it won't charge on either one of the two.
  • 1 more comment
  • Anonymous Dec 01, 2008
    I just got this and I can't get it to charge at all. I wonder if it has something to do with my USB ports as I've had similiar problems with other devices. So is there a power setup I need to do for my USB? I"m running WinXP
  • Anonymous Mar 18, 2009
    I plugged my sansa into computer and won't charge-- it worked once and now can't get it to work again  It just blinks "connected" when I am trying to charge it  HELP
  • ericvamp Apr 29, 2009
    my sansa 2 gb mp3 player will not charge when plugged into my usb . The sansa 2 gb did charge fine before.. but not now. It is recognized but no charge is ging into the battery.. how do i solve tihs problem ?
  • 4 Answers
You MAY have a power glich. In which case, hold the power/menu botton down for 20 seconds or more, then connect it to the computer.It's best if you use a USB input that's NOT part of a Multi-USB base, as those DO cause power gliches.
Posted on Oct 20, 2008
If you have an outlet charger (like for a cellphone) that connects to your MP3, use it. It works for mine. My sansa clip will NOT charge when connected to my computer, but it will when its connected to an outlet (although veeery slowly).
Posted on Jul 19, 2009
I just found out (after changing to a new harddrive) that my Sansa won't charge on the new OS load, I assume because I've not loaded the software\drivers. I re-installed old harddrives (still fully functional) and the unit charged again. Put the new drive back in, unit will not charge.
Also cannot access drive without software. That's stupid. I'd not buy one of these ever again.
Posted on Nov 08, 2008
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
I have an sansa sandisk 2 gig model m250. How do I delete contents that I loaded?
Plug it into your computer via the usb cord and bring up the players contents on My Computer>Player and delete the contents within the folders you want, most likely the Music Folder.
Jul 14, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sandisk 2GB Sansa clip will not charge with USB.
The problem maybe the usb cord or it maybe the hardrive in the monitor hooked up to the network drive. If this doesent help i will try to help as much as possible.
May 22, 2009 | SanDisk Sansa Clip MP3 Player
How do I charge my sansa?
all you do is put the usb in the mp3 and the computer and then the battery will just start to charge it takes about one or two hours
Nov 14, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa clip 2 gb
My sandisk c250 will not charge on my laptop do I need software or can I download a program.When I plug in the mp3 it will not do anything.
Sep 14, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Problems with charging my mp3 player!
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Mar 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I was having the same problem with my Sansa e250. My wife has the e200, and we didn't have any problems with that. I saw that someone on here suggested to lock the mp3 player with the tiny metal switch on top, so I did, and the battery charging icon on the bottom of the screen came on and stayed on, and the mp3 player worked. thanks!
Because of this I would suggest checking to see if it's locked or unlocked and then change it to charge it.
Jan 16, 2008 | SanDisk Sansa m250 MP3 Player
Sansa c250 not working at all!
2 Suggestions: 1) It may be that the battery isnt charged, let the unit charge fully 2) If that doesnt work, its probably time to send the unit back to sandisk
Jul 23, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e260 MP3 Player Logo
1,794 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
