Question about Philips Magnavox 51MP392H Rear Projection Television
Magnovox 55p8288 av does not work
Our AV input has gone dirk as if nothing is tuned? both av1 and av2 just quit.
    Scholar:
  • 33 Answers
Did you recently move the TV, or do you plug a game system in and out posible its as simple as the internal connector lead poped off from use...
I've added the service manual links hopefully you can find a picture of your A/V input and beable to just plug somthing back in...
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Good Luck, hope I helped
Posted on Nov 20, 2008
How do I record from DVD to HDD
DVD player AV out to HDD AV in RCA cable red white yellow
HDD input source has to be AV in you may have to set up a timed program chanel to av in av1 or av2
you may not be able to do this due to copyright embedded signals being detected by the HDD
Oct 17, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
What does AV1 mean on a SAM*TRON TV mean? How do I get rid of it?
av 1 is the source input for the tv
there should be av 2, 3 4 etc and each one isa for a different input item
for example av1 is for the tv -aerial , av2 may be dvd input , av3 may be x box, av4 home theater
how to get rid of it . click on exit or ok
Sep 30, 2016 | Televison & Video
I have a samsung LCD TV. it shows only AV..I can not use it as AV1 AND AV2
You can select its other 2 av inputs by pressing the AV button on its remote control.
Jan 23, 2013 | Samsung P50HP 50 in. LCD TV
How do I tune a DV3 set top box to my TV
The best way would be to connect your DV3 using an AV cable that way you don't have to tune your TV. If your TV has an AV input at the back ( Yellow / Red / White ) all you need is a AV cable and connect the DV3 to the TV using this cable and select AV1 or AV2 according to which socket you have connected. This way you bypass the TV tuner and get better picture and sound form your cable service.
Aug 27, 2011 | Televison & Video
Toshiba back projector 43' how do i make the av
Look at what input you plugged the DVD player into. maybe AV1 or AV2
Now on your remote, or on the front of the TV, push input until it stops on the one that your DVD player is plugged into.
Aug 27, 2010 | Toshiba 43HX70 43" Rear Projection...
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
How do u turn to scart channel without a remote
Not knowing what model of TV you have, the most common ways are either by using the Source button then scroll to AV1 input or if you have a Menu button there may be a sub-menu for Input, again select AV1 (depending on which AV connector you are linked you maight have to select AV2). If you have a DVD or VCR connected to the AV source, then when pressing play the DVD/Tape should automatically switch over to AV.
Jul 08, 2009 | Televison & Video
How do I hook up my dvd player to my JVC model AV-56wp74?
just run your av leads into your AV inputs on tv,then switch tv to AV1 or AV2
May 01, 2009 | JVC Televison & Video
How does my mum reinstall this dvd on a new tv she has lost her instruction manual and i am attempting to help her over the phone!
Advd player does not need tuning , simpley connect red white and yellow RCA leads from the back of your DVD to AV... input of tour TV use TV remote to select the same AV source eg AV1 AV2
Apr 21, 2009 | Yahoo YDP305 DVD Player
My Screen Said "Are You Sure" and "Please Wait" and now, instead of "AV", i have "AV1" and "AV2" and my tv wont show picture from the dvd player OR vcr
You will need to go back into the menu and see what ia available in the video input mode. You may have switched the type of input you can use such as default or componts ect. If you have an isntruction manual, look in there or call the manufacturer, should also be in the instruction or user manual. Good Luck
Mar 28, 2007 | Spectra KT2114 Television
Philips Magnavox 51MP392H Rear Projection Television Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
