Question about Fujitsu Siemens Basic Line 43B1-M 17" LCD Monitor
Monitor Hi, my monitor has red, blue, and green thin lines going down the front of the screen, could you explain what that means and if there is anything i can do? My monitor is only guaranteed for 1 year and unfortunately the year is up!Thanks Maria.
0 characters
1 Points
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
Hi my monitor has bright colours on it and i cant make out what im doin its really bright and hurts my eyes
Turn off the pc but leave the monitor on. unhook the monitor from the pc. the screen SHOULD run a "self test" with a moving white green red blue box. if that box is on a bare black screen and there are no bright spots or cracks or anything weird looking, then the screen itself is ok. If however, you see odd shades of blue and pink and it looks cracked or scratched or has lines in it, then it is time to replace that screen.
Nov 10, 2009 | Dell E173FP 17" LCD Monitor
LG Flatron screen with green line
Hey man the screen is having manufacturing fault ...
please go and replace it immideatly.... with no doubts in your mind
Sep 18, 2009 | LG Computer Monitors
There is a thin bright green line on my monitor
my computor monitor keeps turning a very bright green, When it does I cannot see anything thing clearly, yellow and reds look the same. how do I fix it.? Please help Thank you
Jun 04, 2009 | Sony SDM-HS73P 17" LCD Monitor
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computer Monitors
Red Line
I was just looking at Samsung's site regarding this issue. It is most likely a line of dead pixels. Direct from their site: "The thin red, green, blue, white, black, or yellow line you see running through your LCD monitor is most likely a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced. To set up a service appointment, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your monitor's model number and serial number on hand when you call."
Jun 21, 2007 | Samsung SyncMaster 213 T 21.3" LCD Monitor
Fujitsu Siemens Basic Line 43B1-M 17" LCD Monitor Logo
15 people viewed this question
Top Fujitsu Computer Monitors Experts
sonic boom...
sonic boom...
Owen Barnes
Are you a Fujitsu Computer Monitor Expert? Answer questions, earn points and help others
