Question about D-Link DGS-2205 5-Port Gigabit Ethernet Switch (DGS2205)
Port speed issues with my DGS-2205
I have a green speed light on my switch on the first port. That indicates I have 1000 mbs entering the switch. All of the other 4 ports are capable of speeds of 10/100/1000 yet I only get 100 mbs on the other four ports.
How do I get the full capable speeds out of all of my ports?
Note Green light indicates 1000mbs and yellow light indicates 100mbs. I have 1 green and four yellow.
    Scholar:
  • 70 Answers
Gigabit swich does not enough for a Gigabit network, you also need to get your computers to support it, that means Gigabit network cards, buy if you don't have and you really need to, they are quite cheap these days.
If the above is not the case than it is barely possible, but worths a check, if you are using simple CAT5 cable instead of CAT5E or CAT6 (cable type is written on the cable, see for yourself)cable for the network?
If this is true consider doing a rewireing if really nessesary for speed, but cat5 is ok for gigabit around 10 meters distance for very good speeds.
However to do a little speedtest on your own first is not a bad idea at all, try to copy some big files between 2 computers and check the speed, 100Mbit networks used to do speeds about 8-10 Mbytes/sec that should do it for most networks, gigabit networks can do more, my record in my home network was 50-60Mbytes/sec, but mostly it's around 30Mbytes/sec.
Remember, better cable can do better speed and sometimes length affects network speed if the cable is very long (above 50 meters). And prepare, that you are not really going to reach the theoretical maximum speed of 125Mbytes/sec with common PC hardware. Maybe with some RAID based system or SSD can help you out, but most people don't really need that kind of speed.
Posted on Nov 26, 2008
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
One of the LED is orange instead of green
I also have the DGS-1008D 8-port switch and it connects fine at gigabit speeds between my 5 PC's - I would check the cabling again, as mine was plug and play. As soon as it was hooked up and switched on, I got the green light for the gigabit connection - my 100mb router (also D-Link) connects with an orange light, as it cannot achieve gigabit speed.
Hi there and thanx for the reply.
I have connected PC's with the gigabit cards to the point where the one machine connects at 1Gig. All machines connect at 1 Gig at that specific point. So it is either the cables itself or the connection in the jack itself problem
Mar 10, 2011 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
D-Link DGS-2205 Can I use this device (switcher) to connect two or three computer to internet? At the moment I just can connect only one computer using this switcher. My service provider is Comcast and...
You sure can connect 4 wired computers via the DGS2205, you need to make sure u have a wired modem/router connecting to the switch to have internet
ROUTER > MODEM > SWITCH > COMPUTERS
Jul 03, 2017 | D-Link DGS-2205 5-Port Gigabit Ethernet...
This d-link switch as a warranty periad s/n: pl29287019140 p/n: ies1008de....16g
Problem with the D-Link DES-3026 24-Port 10/100 Desktop Switch (PL35187014575)
Sep 23, 2010 | D-Link DGS-1008D 8-Port 10/100/1000...
We have a d-link 5DGS-2205 in our office (small nonprofit). It has started making a noise almost like an alarm that lasts for one minute and this happens about once a day. Everything is still working -...
The manual can be downloaded from the following link:
Connecting the Switch DGS-2205 to End Node - ftp.dlink.com
The manual indicates that a diagnostic program will run when the device is booted up (powered on). The diagnostic will check all five cable connections for opens or shorts. Indicator lights will identify a port that has a problem cable. If any of the five ports or cables have a problem or are disconnected the LED's on the front will indicate this and probably sound an alarm. the other ports will function normally. the back of the book has a technical support number. Hope this helps. Check your cables and connections. TAS4RD
Oct 04, 2017 | D-Link DGS-2205 5-Port Gigabit Ethernet...
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
Is it worth the extra price for a Netgear switch
For general home networking, you will not see a difference in performance if all you are doing is sharing internet connections / printers.
If you are wanting to share very large files between PCs, then you might consider purchasing a more expensive one.
D-Link makes surprisingly good equipment for the price.
Mar 16, 2010 | D-Link DGS-2205 5-Port Gigabit Ethernet...
D-Link DGS-2205 5-Port Gigabit Ethernet Switch (DGS2205) Logo
871 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
