Question about Sub-Zero 642
New 642 freezer door is very hard to open due to seal sticking
Our new 642 freezer door is very hard to open as the seal sticks.
Force needed is threatening to bend handle
    Scholar:
  • 112 Answers
If the seal or seating area is sticky, wash it with warm water. If it isn't, this is just the sign of a good refrigerator. As the air cools, it becomes more dense and creates a vacuum inside the compartment. With a pliable new door seal which is sealing well, combined with a large door, this can cause a great seal with alot of pressure pulling on it. Smile, this is why your consumers bill will be much better with that new sub-z.
Posted on Oct 18, 2008
Why the freezer door opens when the refrigerator is closed?
I have a refrigerator with a top freezer that was constantly popping open, just enough to let the heat in and melt anything inside. This can also cause heavy frost build up from condensing humidity in the air. The frost can build up on the front face of the fridge where it meets the magnetic gasket on the door making it even harder to keep the freezer closed.
The cause in my case was that slamming the refrigerator door sent a puff of air through the ductwork to the freezer above. The sudden pressure increase popped the freezer door open and the door wasn't heavy enough to close on its own. Since this is a beer fridge in my garage I fixed it by putting a stick on childproof latch from H-D on the freezer door. :-)
If this was our main fridge indoors, I would first check to see how much force it takes to open the freezer vs. the refrigerator section. It should be about the same. If not, check the freezer door gasket to be sure no food or ice is built up on it and that the mating surface is clean. Check that the door is closing parallel to the mating surface. A misalignment would make it hard for the gasket to seal or stay sealed. Adjust hinges if necessary. If all seems ok, check to see if the fridge is level or possibly needs to be adjusted so it tilts back just a bit to make the doors self closing and not fighting gravity to stay closed. If all else fails, inspect the door gasket to be sure it isn't broken or stiffened with age. Inspect the bottom of the door gasket with a mirror. I once had a side by side with what looked like a good gasket until I felt around the bottom of the door. Replace if necessary.
Dec 15, 2016 | Refrigerators
My freezer door wont open, feels locked on one side. water is leaking underneath
Just answered a similar question about this but with the water leaking in this one, I think the door got wedged open slightly and you now have an excessive ice buildup on the inside of the freezer causing the door to stick from the ice buildup. You may need to pull hard to break loose the ice and when you get the door open clean all excessive ice from around the door seal area. Packages inside may need to be re- arranged so door closed properly.
Mar 05, 2015 | GE Profile Stainless Bottom-Freezer...
How do I prevent the fridge door from sticking too much and making it hard to open
Make sure the gaskets and surfaces are clean, any grease on them will make them hard to open. Check the hinges are free and not gummed up. Spilled coke etc, will also cause them to stick due to the sugar acting like glue. Putting hot food in there mayl also cause this problem.
Feb 25, 2015 | Westinghouse Refrigerators
Freezer door does not have the vacuum suction that it did have
Check the door is square to the frame and no shelves are sticking out stopping the door from closing properly. The seal should be magnetic and stick to the frame quite well.Check no metal strips have come off so the magnetic seal isn't attaching to the frame
May 20, 2012 | Frigidaire 20 cu. ft. / 566 liter Upright...
My door won't stay shut. How can I adjust the door or is it a problem with the gasket?
First of all is this top freezer/refridgerator new or has the consumer had it for awhile? If not new, could have frozen food, piece of ice, etc obstructing the door. If you have frost(ice build-up) you could probably turn down the temp adjustment, might not need to be quite so cold, just a suggestion. Open the door and check the seal for damage, there is a magnetic strip in the seal that sticks to the body of the fridge keeping it shut along with vacuum etc. Check seal before calling service (800) # for further advice/ servicing. Good luck, best regards.
Feb 09, 2011 | Haier HRF10 Top Freezer Refrigerator
How do you adjust upright freezer doors? After releveling, the lower opening side corner is sticking out a little and seal is not quite touching, 1/8th".
pull door seal back exposing screws loosen slightly twist door ie. put foot at bottom of door and push or pull top of door.close to see if door mates up good if so tighten screws
Aug 29, 2010 | Freezers
Cannot reopen Sub-Zero 642 freezer door for 50 seconds
Yes, this is normal.  My 642 does the same thing. It seals to be more efficient while trying to cool back down after it has lost heat while open.
Jun 21, 2009 | Sub-Zero 700TR
Freezer door pops open when refrigerator door is closed and water is gathering under vegetable drawers.
Well the water gathering is probably the drain hole plugged,(under bottom drawer),its a round plug that sticks up a little,it turns out like a bolt,--now about the freezer door,how is the door seal?bad as in warped,torn,bent?incase you didnt know there is a magnet inside the seal.also check if the door needs to be re-adjusted
Apr 21, 2009 | Refrigerators
Sub-zero door seal
THE TRUE IS .. replace a door seal is a little pain to replace. YOU HAVE TO INSTALL RIGHT. ( some model using silicon. if you are patient. and able to remove aroun 30 screws. do it. if not. better call a tech........good luck.............................. LEAVE A COMMENT IF IT WAS GOOD FOR YOU
Dec 06, 2007 | Sub-Zero 642
Fridge Door not shutting/sticking
the fridge door stays shut only by strip magnets inside the door seal. cause is possibly that the hinges are out of line or the cabinet distorted. try levelling the fridge and tilt slightly backwards
Apr 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
772 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ACME Sub Zero...
ACME Sub Zero...
Gere knutson
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
