Question about JVC AV-32820 32" TV
JVC TV AV-32870 will not turn on. blinking timer light
Please help
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Posted on Jan 14, 2009
4 Suggested Answers
  • 142 Answers
SOURCE: jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Posted on Sep 30, 2008
ginko
  • 19396 Answers
SOURCE: blinking timer red light on jvc tv, no other functions
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
ginko
  • 19396 Answers
SOURCE: TV turned off itself and timer light (red) keeps blinking
Blinking timer light, No picture or sound.
Ur high voltage is dead,the FBT,the flyback transformer,the big black block of plastic with a red wire with a cap hook to the CRT(tv tube).That is dead.
Sep 27, 2009 | JVC AV-36D302 36" TV
The tv turns on and back off and the on timer light blinks on
Try to reset everything in the menu section to reset the timer for tv some how was activated and needs to be turned off.that might help!!
Mar 01, 2009 | JVC AV-27920 27" TV
RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Feb 28, 2009 | JVC AV-32230 32" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
JVC AV-32870 Power button is missing
I had a friend that had the exact same problem! We did use a remote to turn the tv on and then it was a matter of setting up the menu settings. It was trial and error, but it was worth it. As far as getting the power button replaced, I would recommend call and ask a TV repair person - but the remote worked just fine for my friend.
Jan 06, 2009 | JVC AV-32820 32" TV
On timer light blinks on/off tv does not turn on jvc av-32d502
Well, it sounds like the TV is in timer standby mode and thus preventing the TV to turn on or off.
  • Very simple thing you can try to reset the TV is to unplug it from the wall and leave it unplugged for about 5 minutes or so.
  • Next, replug in the power for the TV and see if the timer mode has been cancelled out.
Regards,
Feb 16, 2008 | Televison & Video
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
Televison & Video Logo
989 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
