Question about Vehicle Parts & Accessories
Toad sterling car alarm lost manual and need stop code.
Lost manual for my alarm and if my battery fails or remote inoperable, I will not be able to start car as immobiliser will operate and I do not have the code to disable it. This will be the manufacturers default code. Handbag stolen with instructions and model number.
  • owencorydore Nov 24, 2008
    bmw m3 series
  • maritamail Dec 18, 2008
    I have imported my car to south africa after installing a toad alarm with you in brittain. Now because of all the paperwork connected to returing from britian and importing, i have lost the user guide. Could you help me to reset the alarm, immobiliser as i think this is why my car does not start now. See, i have replaced the plugs and did not touch anything else but the plugs. I have heard that the immobilizer shuts the spark when starting the car. Could you send me a user guide or installation guide or give advice please
  • 31 Answers
This worked on my car when the clicker died:
Put the car in valet mode. Disconnect the NEGATIVE battery terminal. Put the keys in the ignition and turn it as far forward as you can (as though trying to start it) and let it spring back. Reconnect the negative terminal. This should reset the alarm to valet mode. Programming varies from brand to brand. Contact an alarm dealer and they can help reprogram the remote(s).
Posted on Jan 04, 2009
Lost my keypad 4 alarm & imo its a sterling cat 1 alarm & immboiliser
Posted on Feb 22, 2010
Car alarm comes on when unlock car door with car key can't unlock with remote lost battery out of remote
You can't defeat car alarms. They are designed to stop what you are trying to do! Just go and buy a battery.
make model remote battery
Batterybuyer com
May 20, 2016 | Cars & Trucks
I had the positive battery end changed on my 2003 Toyota Corolla and when new ends were connected the alarm starts and won't stop...I can't turn it off by the remote....I can't even lock or unlock my doors...
Its possible the remote code was changed after install which required a learn and the learn was erased when battery power was lost.
If this is an add-on aftermarket alarm system, the best hope is that somewhere under the dashboard or near the left kickpanel by the floor you see/find a small button mounted there. This is usually the most common install for the override switch by most alarm installers. Turning the key to the ON position then pressing the button and holding for 2-5 seconds will shut the alarm down in most cases if it has such a button.
If it does not have a button, or this is a factory alarm system, its possible the alarm control module fuse has blown or the module itself is stuck or failed, or the receiver for the remote is not seeing the remote. Recheck the connections at the battery, if its an add-on alarm there may have been a constant power loop attatched to the cable that is required to power the receiver/module and was accidentally left off. checking all fuses may also yield a blown fuse that feeds the alarm system controls.
Mar 25, 2015 | 2003 Toyota Corolla
Peugeot 307 xsi model 2002 remote control battery was low mechanic kept on to try starting despite alarm blowing, car not starting engine rolls but does not fire. the car was scanned reads: ECU locked ...
The clue is the remote control low battery (or replaced) == it's lost it's 'code' and needs to be 'reprogrammed'. Until then, the imobaliser (in the ECU computer) will lock the ignition. As soon as you tried to start the car the alarm was triggered (with the ECU locked the engine turns over but won't start).
Take it away from the cowboys and to a garage that knows want they are doing = and don't listen to the idiots who failed to actually read your question and would have you start taking the car apart or replace the starter motor
Feb 04, 2013 | Peugeot Cars & Trucks
Got bmw wiv toad alarm on battery went in thob put new battery in now dont work it does al my electrics
best advice is to remove the add on alarm ,but if its an add on alarm they often malfunction ,failing which some t`ypes of alarm have a button inside the alarm and you press the button inside and the fob to re programme it
Sep 19, 2010 | 1996 BMW 318
1998 toyota Avalon, the car alarm is going off when opening the drivers door manually with the key (remote is broke) and then the car will not start.
Same here... I have a 1998 Toyota Avalon XL. My car battery died. Replaced my car battery, but found out that when you unplug and plug the car battery with this car it engages in security mode (I have factory car alarm). This disables the engine and wont let you turn the ignition aka start the car engine until the remote (keyless entry) "UNLOCK" is applied. My remote is also lost so I cannot disable the alarm.
The only thing I can think of to do is unplug the battery again to disable everything (car alarms are annoying...) and call the dealer to pick the car up and perform the diagnosis. Most likely they will offer you another keyless (ugh... expensive) and/or you could ask to disable the factory car alarm.
I know thats not much help but it seems to be the only option from what I researched currently....
Sep 17, 2010 | 1998 Toyota Avalon
Hi i have a toad A101cl alarm in my car.. it was fitted before i bought the car so i have no user manual or pin-codes etc etc. i had only 1 set of remote keys but now they have been damaged and i cant...
heres the user manuel file:///C:/Users/Administrator/Desktop/toad-a51s-a101-a201.pdf
alternitivly go to
and download from there
hope i was helpfull
Apr 05, 2009 | Vehicle Parts & Accessories
Lost key and alarm remote
first of all always take car of keys and locks of any of your belongings.. as it is very important..
i think you just go through the following link u ll get the answer
<a href="">car alarm installation</a>
Jan 30, 2009 | Chrysler Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
3,405 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
