Question about Northgate WALINN140A Notebook
Trying to find any info on my Northgate M8050D Notebook S/N PNA408020135
Just got this notebook. has no memory, hdd, lcd, dvd-cdrw, wireless or ac supply. it does have the mobo and centrino chip in it with fan and heatsink. you get the idea. its a project for me to pass my time. any direction in finding anything (especially info) on this unit would be gratefull.
dmco@comcast.net intel_opp
I have installed window 7 in my Ibm thin pad but Icant get the audio drivers
i can install your drivers online. if you want contact me
Jan 08, 2012 | Computers & Internet
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
Vaio notebook cloudy/hazy/streaking display following spill
nothing we can do for this problem. throw it away and get a new one
Feb 27, 2017 | Sony VAIO VGN-FE670G Notebook
Ccomponants will not power up
David,
Your hard drive is junk. Replace the hard drive.
May 23, 2009 | Computers & Internet
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Computer turns on automatically when i plug in the power supply
Hi, i am an emachine specialist,
do you get the following:
cpu cooling fan running ?
hdd heard to be running
cd/dvd devices operational?
no picture on screen ?
compdoctor2005@btinternet.com
Dec 30, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
LCD not working
Sounds like a motherboard fault/short, especially if youv'e got on board graphics and if there are smells coming from fan.
Sep 01, 2006 | Toshiba Satellite A85-S107 Notebook
System Freeze
sc122870, try this first disconnect the hard drive cable and then try getting into bios, also try disconnecting both cables to the cdrw and to the hard drive and try to get into the bios. Sometimes if the pin assignments on the 2 drives are wrong, bios will freeze. If it does the same problem with the 2 drives unhooked then it might be your mobo.
Aug 19, 2006 | Mach Speed P4MBMS Motherboard
Northgate WALINN140A Notebook Logo
65 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Tom Chichester
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
