Question about Presto HeatDish Compact Heater
No heat Presto Heat Dish footlight works but no heat.
  • tkgso Nov 17, 2008
    I have the same problem. It appears a "fuse" has blown. It just happened this morning.
  • VishalFixya May 11, 2010
    Is there anyone who can help me check my heater and help in doing the wiring if that is the issue.
  • 56 Answers
Since the light is on its own circuit this dont surprise me at all. The most likely cause of this is the contacts on the inside of the heater. the wire inside of the unit is very small for a heater, bad design, and is conected by spade conectors. my wire in mine burnt through and did the same thing. I bought some good thick wire and rewired the unit direct and this seemed to fix the problem. If you need further assistance check out some of my other solutions in this same area.
Posted on Dec 27, 2008
Where can i locate the on/off machinism for the presto heat dish?
Handy top-mounted thermostatic control maintains the desired temperature automatically plus it has a special safeguard features turn the heater off automatically in case of accidental tip-over. Because of this technology they eliminated an on/off switch. You have to unplug it if you want it to be totally off. sorry
Mar 19, 2010 | Presto HeatDish® Plus Footlight® Electric...
My presto heat dish doesn't emit enough heat anymore, even though it's only 4 months old. What do I do?
Go to the Presto website and email them. They are really helpful.
http://www.gopresto.com/information/feedback.php
Dec 30, 2009 | Presto HeatDish Compact Heater
Clean dish
'tdulany's remedy for cleaning the dish on the Presto Heat Dish probably works well, but how do you get past the grill covering the dish in order to clean it?
Nov 26, 2009 | Presto HeatDish Compact Heater
Presto Heat Dish: footlight lens
The wattage of the replacement bulb should be 4 watts or less. Don't know the wattage of a C7. It is still safe to use. You could call Presto at 800.877.0441 or find a 4 watt bulb.
Jul 06, 2009 | Presto HeatDish Compact Heater
Presto parabolic makes loud buzzing sound after a few minutes of
The metal dish must be dust free or it will transfer heat to the safety device. If this is not the solution call customer service at 800-877-0441
Jan 13, 2009 | Presto Like Parabolic Heater Heat Dish
Presto HeatDish Plus Footlight - Parabolic Electric Heater Where can I find these??? They are great.
Or try a thrift store for a used one. Do a search for "heat dish" without the quotes, and you will get a few hits. Amazon.com has a few of this type of heater.
Aug 18, 2008 | Heating & Cooling
Presto Heat Dish w/footlight
This heater must be flat on the floor or it will buzz, and the metal dish must be clean or it will transfer heat to the safety device. If this does not solve the problem call customer service at 800-877-0441.
Jun 14, 2008 | Presto Heat Dish/Electric Heater with...
Presto Heat Dish
The hardest part of cleaning the dish is that you can't get your hand inside the cage surrounding the dish. What I did was to use a wire cutter to snip enough pieces of the cage off so that I could get access to the dish. If you do it carefully, it looks as if it was intended and doesn't prevent the cage from working. If you think of the cage/dish as a clock, I cut all the strips between 9 and 11, and 1 and 3. Easy to clean the dish afterwards.
That might not solve the buzzing problem, though. It didn't solve it for me.
Feb 07, 2008 | Presto HeatDish Compact Heater
Presto Heat Dish Blows Circuit
It sounds like the heater is drawing more amps than your fuse is capable of handling. look at the i.d. plate and see what the wattage is for the appliance.
Nov 08, 2007 | Presto HeatDish Compact Heater
Presto HeatDish Compact Heater Logo
337 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
