Question about Philips 32PW6006 32" TV
TV won't come on and can hear a contstant clicking in the back.
Have had an intermittent problem whereby the TV switched off by itself, often when we were first turning it on. Now it just won't turn back on again, although occasionally if we leave it for a minute, we'll hear a bit of sound but then nothing. Whilst this is happening, we can hear a contstant clicking noise at the back of the TV. A friend seems to think that the transponder has gone but this can be fixed as opposed to being repaired. The World Cup is just about to start and we're buying a house at the moment, this is just sod's law! I'm looking forward to my car engine blowing up tommorow just to top everything off!! Any help/guidance/quotes of possible costs massively appreciated!
  • 3 Answers
Problem is the CRT 100% after a while u will get color fluctuation on the cathode which is causing the problem and then the power supply is switching off detecting a high current peak.Why?? Because one or two cathodes (my case) get nearer (provoking discharge in the heater circuit) or shorted to the heater (later)because of the heater oxide buildup. Problem is random and tv could work for days even and have days when will cause the problem every few minutes(grrr...).Solving: best way is a tube rejuvenator and should be made by a qualified technician(special equipment needed).BTW this problem is common to this type of tv sets CRT's are made i chech republic and all suffer from the same problems.Other home kinda fixing just read up about using g2 voltage to try rejuvenating the CRT but not much success guaranteed but helps a bit switch off rate decreases but doesn't disappear. Gluck
Posted on Jun 05, 2007
    President:
  • 3,130 Answers
Cheer UP!!! Its not that bad Im sure? Ok first off theres nothing in that set thats called a transponder, so dont let anybody work on your set thats not a technician. They can be hurt or killed. Your problem could be a simple cold solder connection on the sweep board but the longer you wait with these types of repairs the worse they get as they cause parts to go bad in the power supply, as it sresses them badly. Call an authorized servicer and ask for an estimate, and if you like the set and the cost is reasonable go for it, and maybe get it back before the cup games are on??!! Good Luck
Posted on Jun 05, 2006
SONY LCD KDL-S40A12U SWITCHES OFF BY ITSELF
There may be a "Power saving" feature on the TV. Check in set-up and adjust time for auto shut off.
Jan 02, 2018 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
Tv won't turn on- its in standby mode. the young lad had the remote before it was turned on.... could he have pressed somethin on the remote which is now preventing it from coming on?
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure.
will need diagnosis by a repair shop. Too many different components it could be for me to guess. but
the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
Feb 21, 2018 | LG 50PJ350 50 in HD-Ready TV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tv switched itself off and won't come back on
pls describe the type of tv it is ?
Aug 04, 2011 | Televison & Video
My TV has developed a problem whereby when attempting to turn on teh TV, it goes througha process of clicking itself on and off for a few minutes until eventually it manages to power up and we can watch...
For a temp.fix,tries unplug,replug the tv back about an hour later,so the tv power and other boards to reset itself.Tries websites like Shopjimmy.com.Ebay.com to buy a refurbish power supply board for the replacement.
Sep 28, 2010 | Televison & Video
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Philips 32PW6006 32" TV Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
