Harman Kardon DVD 101 DVD Player
Problem for Harman Kardon DVD 101 DVD Player
DVD 10
By DronJes on Jun 05, 2006
I have a HK DVD 10 DVD Player.
It no longer plays dvd's, it sticks on 'Reading'.
After a while it comes back and says DVD incompatible, regardless of what DVD I play.
I have tried it with DVD's that I own and that I have played in the player numerous times in the past.
It does however continue to play music CD's.
Any idea's?
David
Same Problem
Jan 22, 2008
-   My Samsung DVD and VCR V2500 is having a problem playing DVDs. It plays VCRs very well but the DVD reads until a ''NO DISC" reading display appears on the TV screen. Befrore it was playing very well. Any idea?-   Guest
Dec 18, 2007
-   1. My polaroid portable DVD player doesn't recognize some DVDs and VCDs. It is able to play some discs but after a while, it gets stucked, sometimes it says bad disk at the time of loading.
if i use lens cleaning CD will it clean DVD player's lens too?
2. Also, combo drive of my PC is able to recognize only brand new authentic CDs. The CD that i have written on PC are not recognized by my drive. And when i try to write new CDs on this drive it starts and gets stuck on 2-3% (using NERO). Please help.-   whoami999
Best Solution
posted on Jun 07, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3613 votes
It either needs some cleaning to the lens, or it might be that the player can't make the switch to read DVD's. It's my understanding that the laser has to change it's characteristics depending on the media it's reading. I believe what the drive does is try different laser settings (such as beam size, and intensity) until it can read the media. Your player might have a fault with this feature.
If opening the player chasis and brushing dust of the lens doesn't fix it, you should take it to a decent lab to get an estimate for repair. It might be minor, as some further cleaning, or it might be more critical, parts replaced etc.
Good luck
Was this helpful?
Yes
No
Popular Solutions for Harman Kardon DVD 101 DVD
Questions and Unsolved Problems for Harman Kardon DVD 101 DVD
Do you recommend Harman Kardon DVD 101 DVD Player?
Answer
Answer
i am having problems playing dvds or avi's on my shinco sdp 1735. DVD: does not even start playing... (More)
Answer
My JVC dvd player has the word "PAL" on the display. What does this mean?
Answer
background green
Answer
turned player off turned player on later no power checked fuse ok, opened box power to board... (More)
Answer
Have checked fuses and all ok but uinit has no power and will not turn on, any ideas? Thanks
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
