Related Tags:
This problem should be removed because:
Problem with Vivitar (1607225) Telescope
eyepiece for telescope
Hello, I have a cheap Vivitar telescope. I was wondering if I could increase magnification from 100X to as much as possible by replacing 6mm eyepiece with another one for example 4 or 3 mm. OD of the scope's eyepiece is .965. I know that most eyepieces are 1.25OD. I can buy .965 to 1.25 converter, but I have a hard time finding innexpensive <4mm eyepeace. Could you help me locate such an eyepiece?
Thank you in advance,
Tony G.
Solutions (1)
You may be able to find these for sale on:
www.astromart.com
However-- it is very doubtful if your scope can exceed 100 power without the image degrading. I normally use 100-150 power MAXIMUM in my 8" LX90 ---usually I use 50-100 power.
newbie needing eyepiece advise
I have just purchased a 114mm reflector telescope from Celestron. It came with one 10mm and one 25mm eyepiece. I've been able to do...
no lens
bought a vivitar 50x/100x refractor telescope for my son and it did not come with any lens. how can i buy them
Can not see out of scope...missing internal lens?
i need to purchase the
i need to purchase the meade polaris model # 60az-d eye pieces that you use to look through the telescope.
Add Your Solution
manual for a JCPenny telescope model #0120
need a copy of the manual on line
Fix-O-Meter
92
92 people viewed this problem
- 0 people are following this problem. Be the first!
Top Vivitar Telescope Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Hate to break it to you but that little telescope will never reach 500x--- under perfect sky conditions and perfect OPTICS the rule is no more than 50 times aperture-- your aperture is about 3 inches-- or less-- so 150x is the maximum possible magnification under PERFECT sky and PERFECT scope conditions--
Once you exceed the maximum optics the image just gets BIGGER and FUZZIER AND DIMMER! --
