Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan 2450 Woodmaster 2.3 ci eng.
I have a Poulan 2.3 ci eng. #2450 Woodmaster. It starts fine, and when I start to cut something it bogs down. Tried new air filter with no help.
  • Anonymous Oct 24, 2008
    I have poulan 2450 I can get it to start and run only at high rpm's when I let off the throttle it bogs out and then is very difficult to restart seems like its running way to rich on the low end and ends up flooding itself out. The spark plug is soaked with gas and when I dry it off and put it back in it will fire on the first and second pull but then no more after that and then the plug is soaked again. I need some advice on adjusting the carburator. The air filter is clean and that screen in the exhaust is clean. I think the problem is with the carberator. Any suggestions or help?
  • 52 Answers
Hi Guest,
My name is Dennis and I also have the model you are having difficulty with and I can only repeat the instructions from the owners manual (with personal comments) because they have always served me adequately I hope that will serve your needs.
There are three adjustment screws on the carburetor labeled
H (for High speed MIXTURE)
L (for low speed MIXTURE)
T (for idle SPEED SETTING)
They are located just above the primer bulb. If your saw floods so soon in the starting process the idle mixture setting can be set too rich and the speed may be set too slow. Remember the chain will not move when the idle speed is set correctly with a WARM ENGINE!
Adjust the idle speed to just below chain movement WITH A WARM ENGINE this is just below the activation RPM of the centrifugal clutch. Let the engine run at a higher speed than idle until it is warm -- 3 min -- you may have to keep goosing it until then.
Please don't exceed the limits of the plastic limiters when making adjustments.
If you haven't adjusted the mixture screws you may just have to adjust the idle speed and that can start my turning that screw all the way in to the stop and then back out 4-1/2 turns for a good place to start. FAST IDLE -- Adjust the speed until the engine runs with out the chain moveing. Adjust clockwise to increase speed. Cclockwise to decrease engine speed.
Accelerate the engine and if it stumbles and makes too much smoke it's too rich turn the LOW SPEED MIXTURE (in) clockwist in 1/16 a turn incriments NO MORE at a time because a twocycle needs to run at a setting foe a short time to realy prove the setting. dont run it wide open to warm it up but it should be at a fast idle. Nothing you do will be proven correct untill the engine is warm.
Good Luck
Glad to be of assistance - please rate the solution because I will learn from your rating. Thank you
Your IDLE MIXTURE may be too rich causing the engine to flood.
Posted on Oct 28, 2008
How do I adjust the carburator on a poulan wild thing 2375 chain saw that bogs down when cutting and is hard to start?
there are two screws on the carb start by turning them all the way in then 3 full turns out and then make half turn adjustments until you get it right..
Aug 06, 2014 | Poulan Garden
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
Brand new today Poulan P1500..Started, warmed up. Went to accelerate and it just bogged down and died with no cutting load on it. From what I am reading on forums Poulan is going to give me problems. I...
you have 2 options, return it or use a dremel tool and cut a slot in top of low speed jet screw and turn counterclockwise bout 1/4 turn, keep in mind if you do this it can't be returned, I have seen a lot of good poulans and a lot of bad poulans, flip a coin !
May 04, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan 16" saw, start fine, runs fine until it
A couple of ideas, it could be a fuel tank breather issue, when it starts to die just try loosening the fuel cap, if the saw picks up again you will need to change the breather, the only other thing i can think of is a bad ignition that is breaking down when hot, the only aswer to this is to replace the ignition unit
Apr 08, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Chain saw starts fine, idles fine, and powers up fine when not cutting a long how when starting to cut a log it bogs down and dies. Does anyone know how to fix this problem or what’s wrong with the chain...
Two things that can cause this problem. 1. Your carburetor is not set properly and is not letting the engine get enough fuel under a load. 2. Your chain is binding when you put the chain bar down on the log. Make sure your front chain sproket is turning free and is not too sloppy.
Sep 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan 2450 chain saw which runs great for awhile and then won't run or start. I checked for spark on the plug and none there. A week went by and I checked it again and now it works. So I...
It does happen they quit when hot. More often they just quit.
There are 7 different "2450 Gas Saw Types" here: (Type 1 $25.35)
There is a help link on top that will eventually find someone with a pulse. If you go this way please have your saw within easy reach before calling. HTH
Good for you on the spark test and isolation of the problem. You also listed the make and model. I think I'm in love, LOL.
Thanks, it makes our help easy.
Oct 19, 2009 | Poulan Pro Chain Saw 46cc 20"
Idels good but when i start to cut it bogs doun
Either the spark arresting screen is clogged with carbon, or the carb is out of adjustment on the high speed jet.
Mar 31, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Poulan 2450 Woodmaster Chain saw(2.3 cu. in, 18 in)won't start
It may need the carb rebuilt. The diapharm may have gotten stiff and inflexable.
Mar 15, 2009 | Poulan Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
1,951 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
