Question about GE JVM1870 Microwave Oven
Microwave/convection oven sudden loss of power to 9 year old ge microwave/convection oven model# jvm1190ay002. does it pay to have it repaired.
  • mhmail2 Oct 20, 2008
    your response has been most helpful. thank you. in answer to your question "does the light go on", the light does not go on, the clock does not work, there is absolutely no power at all. it just went blank and died. hate to dispose of it if it is repairable at a reasonable cost since a comparable new one is aboit $580. would appreciate any further advice you can offer. thanks again.
  • GE Master
  • 9,098 Answers
Does the light come on when you open the door?
It may be a fuse or thermostat or thermal cutout. These are all quite affordable repairs for you or a friend to do.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Also at our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 20, 2008
  • William Miller
    William Miller Oct 21, 2008
    I would refer you back to my solution and advise you or a friend to unplug it, remove the grille and control panel, and try to find the mini-manual. The video is helpful for this.
    Also, the fuse may be immediately visible right away behind the grille or control panel.
    Then refer to the mini-manual for checking the magnetron thermostat.
    If the fuse and magnetron thermostat are okay, then you need to check the oven thermostat, which is located on top of the chassis.
    You'll have to pull the oven from the wall to check that. I'd recommend you refer to the installation instructions. You can download GE owner's manuals and installation instructions here.
    If and when you need to look up parts, enter your model number is this format: JVM1190AY02.
Dead ge microwave
magnetrons work only when the unit is cooking
it smells like an insulation from overheating wire so could be a fuse and failing transformer
take it in for a proper diagnosis and quote but if it is over 2 years old the cost to repair could be more than a replacement unit
May 26, 2017 | GE JVM1790SK Convection/Microwave Oven
GE Profile convection JVM1790 will not heat. Everything else works but not heating. The oven is only two years olds. Any suggestions?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Jun 16, 2011 | GE JVM1790 Convection / Microwave Oven
My Advantium over is approximately 9 years old. I heated up broccoli last night for dinner and then it just went out. There is completely no light on showing the time and I checked the breaker switch. Do...
check the wall socket to make sure you have electricity to the plug. Secondly then check to see of the appliance "fuse" has blown, simple repair. If not, you have a costly serious issue.
Oct 07, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a ge model JVM1850. It is 6yrs old. Today it suddenly did not heat a frozen small item thru. Does this sound repairable or do I need to consider replacement? It is above oven.
well!!!!!! its 6 years old,,,,my bet is the manatron has failed,,,and thats a pricy part to buy and have fitted,,,
you may find in the long run its cheeper to just buy a new microwave,,at least it would be a new one and not 6 years old! and not a patch up job
Jun 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
When i push start on the oven nothing happens but the timer is wo
bad relay on control board . not worth it cost to high ( ge board 145.00 to 230.00 ) and with the oven @12 years old i dont think you would find it at price SORRY . please rate this answer , i need the rate to get my "wings' thanks
Jan 16, 2009 | GE Advantium SCA1001SS Convection /...
Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
Nov 09, 2008 | GE JVM1190 Microwave Oven
GE JVM1870 Microwave Oven Logo
98 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
