Question about Acer Aspire 3680 Laptop
Wireless not ok - Acer Aspire 3680 Laptop
  • fixyaixya
    fixyaixya May 11, 2010
    please provide more info on your system. is it an onboard wireless or is it a plugin wireless card? what system are you using? when and why did the wireless stop working?
I can't get my Macbook setup to use the Lexmark x6650. I used the install disc and the wifi light on the printer is green, but I still cannot figure out how to setup my Macbook to print to is...
Print the network settings page to identify if your printer is connected to your wireless network:
1. Press Setup on the printer operator panel.
2. Press the right or left arrow button until Network Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address. SSID should be the name of your wireless network. Otherwise, you may need to reset the printer's wireless network settings.
How to reset network settings:
1. Press Setup.
3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, press OK.
4. Press the right or left arrow button to display Yes, pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark Wireless Setup Assistant on your Mac.
Sep 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
Oct 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
How to hook up the wireless feature???
Press the wrench key on the printers front panel and then look for wireeless option or network option in the menu..Press ok on wireless menu or network option and then look for an option Run Wireless setup wizard by pressing right arrow key...then press ok on that and type in the neywork name of your wireless router known as SSID and after that press ok...then type in the security key of your wireless router known as WEP or WPA Key,,press ok.. it will attempt to connect and wil give u a message successfull..now run the software on computer and select wireless install option on computer and follow the instructions
Sep 02, 2010 | HP Officejet 5610 All-In-One InkJet...
Router works OK with ethernet connection, not OK with wireless
There are several problems that can cause the wireless connection to drop.
Please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Apr 01, 2010 | NetGear WGR614 54Mbps Wireless Router...
Power light is red. Hub is OK. No wireless and Internet connects
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to http://192.168.0.1 and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Ok i have the password
press the "start" and "R" keys.
type cmd in the box and click OK.
type ipconfig /all
look for wireless adaptor (if using wireless) or network adaptor (without wireless if not using wireless),
the local IP should be there.
Aug 27, 2008 | NetGear RangeMax WPN824 Wireless Router...
Security
ok then you have to go in the device and select the wireless option then in that you select wireless security in that you choose the wpa type then give the password then save the setting ok you get the secure wireless network no one can use even the password know.
Aug 11, 2008 | Linksys Wireless-G WRTP54G Router
Dell wireless software is preventing me from using windows wireless software
do not worry about it, to start windows,
click start > run > type services.msc and click ok
you would be in the services page, scroll the page to the bottom, and from the bottom 3rd option, you would find wireless zero configuration, open it and start the service, and click ok, and now richt cick yoyr wireless zero config icon, click view available wireless networks , click change the order of the preferred networks, and under the wireless networks tab, select use windows to config your wireless network option, and click ok, tat would start windows,
check it out, for any more qurreies, revert back
Dec 08, 2007 | Computers & Internet
HPL7780 and Linksys WRT54GS V7
That usually happens when you are going to connect the printer PRO using the wireless. To avoid that problem, try connecting the Printer using the Manual Setting of the IP.
Solution
NOTE: If the router has an outdated or firmware that was not supplied by the manufacturer, update the router to the latest manufacturer-supplied firmware. Set a Manual IP address on the HP All-in-One
  1. Change the IP settings to Manual from the HP All-in-One.
    1. On the front panel of the HP All-in-One, press Setup .
    2. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Network , and then press OK .
    3. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Advanced Settings , and then press OK .
    4. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select IP Settings , and then press OK .
    5. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Manual , and then press OK .
  2. Set the IP settings from the Manual IP Settings menu using the following instructions. For this item... Do the following... IP Address Type a manual IP address on the same subnet, but outside of the DHCP range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway.
  3. Run the Wireless Setup wizard and try to associate the HP All-in-One to the wireless network.
Workarounds Connect the HP All-in-One via a Wired Network
  1. Disable Wireless Radio. Follow these steps to turn off Wireless Radio.
    4. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Wireless Radio , and then press OK .
    5. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Off , and then press OK .
  2. Connect an Ethernet Cable to the RJ-45 connector at the back of the HP All-in-One.
  3. Connect the other end of the Ethernet cable to one of the LAN ports of the router.
  4. Turn off the HP All-in-One by pressing the Power button. Turn on the HP All-in-One again.
Connect the HP All-in-One via Ad Hoc Wireless Network
  1. On the HP All-in-One control panel, press Setup .
  2. Use the down arrow button (c01155210.jpg ) to highlight Network , and press OK to display the Network menu.
  3. Use the down arrow button (c01155210.jpg ) to highlight Wireless Setup Wizard , and press OK . The Setup wizard searches for available networks, and the color graphics display shows a list of detected wireless network names (SSIDs).
  4. Use the down arrow button (c01155210.jpg ) to highlight your wireless network SSID, and press OK . If any encryption is configured in the computer, the wizard will prompt for the WEP key.
  5. Highlight the letter or number on the visual keyboard, and press OK .
  6. Highlight Done on the visual keyboard, and press OK .
  7. Press OK again to confirm the settings. The HP All-in-One will try to connect to the wireless network. Once the wireless network is successfully setup, a message should appear stating that the connection has been successful.
  8. Press OK .
Source: www.hp.com
To get the technical document click here ==>> Document
Please let me know if the issue wont resolve the problem so that we can go ahead and do another workaround.
thank you.
adonscott
Aug 21, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
