Question about Sony KV-27S42 27" TV
I get 4 blinks as a code what error is this and how do i fix it
  • bogdanbj Jan 01, 2009
    Same problem here... I was looking to upgrade anyway, but I wanted to keep the old TV too. Anyone knows what those 4 blinks are, and expensive is to fix?
    Thank you
Hello, I get 4 red blinks comming from the stand by timmer.
Posted on Oct 18, 2008
How do I fix a Panasonic TC-P50C1 Plasma TV with a 10 blink code?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Mar 16, 2016 | Panasonic TC-P50C1 Plasma TV
How do I fix this.panasonic Viera tv power supply issues.?
http://electro-medical.blogspot.com/
Feb 13, 2016 | Televison & Video
Sharp Aquos LC46D82U Power & OPC blink together once, then Power twice alone. Where can I find the error codes to fix this?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Sharp Aquos Televison & Video
Tv problems
Check the error code...you can get a list of them from www.TvRepairKits.com - look on their tips page. If its a 2-2 error code or if its flashing a 2-2 blink pattern then your convergence has gone out in most cases. If it just blinks constantly - with no real pattern - then its likely the well known blinking light of death issue - bad capacitors. You can get fixes for both at the above site.
Mar 08, 2012 | Mitsubishi Televison & Video
Hi! I have a Sony KDL-40s2530 that stopped working properly. When turned on the picture goes on for about a second then it turns off and the red light at the lower right starts blinking four times with...
Most likely this:
4X Blink error code = Balancer Error
The 4X blinking error code is used on models which have a dimming LED backlight.
If a failure happens the TV will shut down and display this diagnostic code.
Contact Consumer Electronics support for repair options.
http://esupport.sony.com/US/p/support-info.pl?info_id=932
Oct 20, 2017 | Sony Televison & Video
What is error code 6500?
This is an error indicating a problem with the Logic Board Assembly. It's probably not worth fixing, with printer prices being fairly low.\
According to the MP800 Service Manual:
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Green (COPY button), or
Alarm LED Lit in Orange)
Service call errors are indicated by the number of cycles the Alarm LED and COPY button blink, and the corresponding error
code is displayed on the LCD.
*Cycles of blinking in orange (Alarm LED) and green (COPY button) - 20 times
*Other hardware error - Error
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
Aug 21, 2010 | Canon MP830 All-In-One Printer
Light blinking 3 times - no remote - won't come on
You have an error code. If you cut electricity to the unit and wait about 20 seconds before powering it back up, the unit will come back on again. There are serveral error codes associated with 3 blinks, I'd recommend instaling the remote controll to determine exactly which one it is (instructions are in the installation manual).
The most common error code associated with 3 blinks is a 16 code, which is typically related to scale formation in the heat exchanger. This error code can be fixed by performing a descale.
Feb 25, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Error code 1 2
if it does it again i would check for bad caps
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Sony KV-27S42 27" TV Logo
279 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
