Question about Tomtom GPS
Have pressed wrong Language on starting up........... acn only get Dutch !!! Can you help me please, This was a gift today.
  • 63 Answers
I suggest you get someone who can Read/Speak Dutch aswell as English. And ask them to find languages or something similar, But I'm afraid there sis nothing else otherwise that we can do.
Thanks for using FixYa
Posted on Oct 17, 2008
  • Josh Howard
    Josh Howard Feb 06, 2009
    Actually,
    I have just realised if that hasn't worked mayber around there should be a small button. You should need a pen to press it will reset it. Whilst resetting Make sure that any Map Cards are removed
Hello i have my machine Ir 3530 i want to change the language from dutch to English
Dear
go to COPIER > OPTION > BODY
<Adjustment method>
XXYYZZAAXX: Country (UP), YY: Language (ja), ZZ(00) Destination,
AA(00): Paper size type
The display contents conform to the display method of
(COPIER>DISPLAY>USER>LANGUAGE). Enclosed in the brackets
are defaults. The country and language are only displayed.
<Operating procedure>
1) Select <CONFIG>.
2) Select an item to reverse its display. Then press the + or - key to change
the contents.
3) Each time the + or - key is pressed, the contents change sequentially.
4) Display the intended contents at all items and press the OK key.
5) Turn the main power switch OFF and ON.
thanks.
Jan 29, 2015 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Change language
power off then power on when memory starts counting up press and hold ok button until all three lights stay on release button find language then arrow up or down until english appears and press ok button
Oct 22, 2013 | HP LaserJet P4015N Printer
Change language back to english on polar heart rate monitor ft4
I had the same problem. So I will try to guide you by button push method (because I didn't understand anything in Dutch that said on the panel). If you look at the polar main wrist watch (easy to say) you will see 5 button. 2 of left and 3 on right. 2 left are top -backlight (21) bottom - back or exit from menu (22). The 3 right buttons are top - scroll up (31), middle - menu (32) and bottom -scroll down (33). Now we know the button number here we go.
Hold 22 for 3 sec. You will see current time showing up. Press 33 once -- Setting ---> press 32 once ---> watch time and date ---> press 33 three time ----> general setting shows up ----> press 32 once ----> button sound shows up ---> press 33 twice ---> language shows up --->press 32 once ----> language blinks ----> press 33 or 31 till you see english or your language of choice ---->press 32 once ----> language is set ---->press 22 for 3 sec and you are back to the watch menu. Hope that helps. This will guide you even if you don't understand anything from the language.
Apr 26, 2012 | Polar FT4 Watch
Bought today a TI-84 Plus. I try to change the language to Dutch. When I press APPS I see no language indication (ENGLISH) or other. What is the solution please?
By default, a brand new TI84Plus SE comes preloaded with a certain number of European languages. If you do not find your (European) language just go to the education.ti.com web sites (Download area) Select the type of downloads, the calculator family etc. You will be taken to a page with links to your desired language. Download the software and use the TI Connect application to transfer the app to the calculator. You might be interested to know that there are also some applications in Dutch (peridic table of elements).
Sep 01, 2011 | Texas Instruments TI-84 Plus Silver...
How do I change the language from German to English
Well you may please follow the steps below to change the language to English on TI-84 Plus -
• Press the [APPS] key.
• Under the applications listed select the language currently on the calculator (For example Francais, Espanol, Dutch...) and press [ENTER].
• On the Language Localization screen, the choice to select a language is given. Select English and press [ENTER].
Good Luck!!
Thanks for using FixYa!!
Aug 20, 2010 | Texas Instruments TI-84 Plus Silver...
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
Sep 21, 2009 | HP LaserJet 4 plus Printer
Change dutch language to english language before instalation
i used kaspersky 2010 and it was in russian.. i used to chage the language by pressing ctrl+shift+alt +f12. try it! it works!
Apr 21, 2009 | Kaspersky Labs Internet Security 2009 Full...
Change Language on Brother MFC-215C
So here you go:
1# Call brother hotline for info what is the 4 Digit eeprom code for England.
2# If you have the info (e.g. 0004 -> Check by help of brother hotline because I am not sure what code you need for GB!!!)
press menu then start bk copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press 7 then 4. You will see the dutch eeprom language code. Press the 4 numbers given to you by brother hotline. You should see the 4 digits. Press start bk copy to confirm. machine will return to maintenance.
press 9 then 9 to leave the mode. machine will come up again with english language ;-)
BEWARE: IF YOU PRESS A WRONG DIGIT CODE THE MACHINE WILL BE MALFUNCTION AND CANT BE FIXED ANYMORE!
Dec 30, 2007 | Brother Multi-Function Center® MFC-215C...
GPS Logo
29 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
