Hi, you can drain the water by disconnecting the grey empty hose putting the end in a bucket and lowering the pipe flat and below the tub level, the water will empty under gravity into the bucket.
When its empty
CLICK HERE to follow the instructions ho how to check and empty the filter of any debris, then try the machine again, is it still does not empty then suspect pump failure.
hope this helps.
