Question about Panasonic TH-42PWD6UY 42 in. HD-Ready Plasma Television
Tv turns off after about 5 minutes
When ever i turn on the tv it turns on but goes off after about 5 minutes.when i try to turn it on again it repeats thesame process.pls can you tell me what to check to effect the repair?i am a technician. i checked the board and seem not to see anythign wrong.i have done some repairs on some projection tvs through a service like this and it has worked.i believe your information could also be of help.
  • lingrasso Mar 09, 2008
    i have the same problem, tv turns off after making a funny whistling sound.
  • Anonymous Dec 26, 2008
    I got the same problem. In Brazil Philips says it´s a power suplly problem. 30% of new plasma tv to fix it.
    President:
  • 3,130 Answers
I looked for that model but it isent in my data banks?? You should try to get a service schematic on the set first. Next look in the power supply and find the power supply main regulator IC. Hook up a meter to the output pin and turn the set on. If the voltage is slightly exceding the value of the IC wait and see what happens . Now right before the set shuts down, does the voltage swing high?? If it does its the IC. It should be a 125 to a 135 volt regulator and if it goes higher then 130 to 140 its bad as I said. If this voltage dosent change then the problem is in the High voltage section. Find the sweep Ic and locate the x-ray protection pin. Monitor the voltage on that and see if the voltage swings high when the set shuts down. I it does your gonna need to check out parts in the horizontal sweep circuit and if you got a scope use it. But remeber always use an isolation transformer when trouble shooting these sets or the meter or scope could blow out the power supply . Good Luck and Be carefull
Posted on Jun 05, 2006
SOURCE:
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
KF50XBR800 Rear projection LCD TV on and then standby
from how long you have this problem? and what made it start?
do u remember the cause?
Dec 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Tv goes right off as soon as i turn it on
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
IF this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 20, 2010 | Mitsubishi WT-42315 42" TV
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Panasonic TH-42PWD6UY 42 in. HD-Ready Plasma Television Logo
448 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
