Need to fix CCA Values for my Samsung DLP HLP50563W, got a new color wheel
Got a new color wheel and I need to fix the CCA Values... Can someone please help me????
  • Anonymous Nov 04, 2008
    I have the same prob, I used the little card it came with to change the values but it still did not look as good as the other color wheel.
  • Anonymous Mar 24, 2009
    I had numerous color wheels installed with the attached cca values and it has never looked as good as the day I got it. Dark images look muddy, green, purple, and blocky.
The new color wheel should have come with a sticker that has a table on it with a bunch of numbers filled in. I think you enter these numbers into the TVs maintenance mode: using the remote with the TV turned off, press
mute 1 8 2 power
The TV powers up and you will see a menu on the left side of the screen. I don't know the exact procedure, but look for something called CCA and then enter the numbers from the sticker.
I just replaced my color wheel and it came with the sticker, but I did not know what it was for. I lost the sticker (probably got thrown out with the packaging). Now must buy a new color wheel and take better care of the sticker.
Posted on Nov 11, 2008
Samsung HLP4663W I have changed Bulb, Ballast, and Color Wheel, Yes, removed the Jumper and set to CW2 too!(color wheel had no sticker with CCA Values or Actuator or Index Delay Values on it) I set the...
th dmd pcb can somtimes cost as much as a rebuilt light engine that comes with the dmd pcb colorwheel and dlp chip. look into a rebuilt light engine from tri state modules or pts electronics.
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Replaced my Samsung HLP4663W color wheel and the
The jumper if it has it usually causes the color to look funny blue instead of normal.
It is located on the DMD board--the metal box on the light engine where the two plugs from the color wheel are.
It will be in a small opening on the metal shield that covers it--small and rectangular in shape--it has a small metal tab across it--it jumps two pins--
if it is there with a hemostat or small needle nose pliers pull it carefully out and see what you have--The CCA adjustments are done in the TECH MENU--look to see first if the jumper is there and remove it.
A lot of places that sell the wheel do not tell people about this.
If this has helped you rate this solution, as I do this here for FREE.
sd tech
Nov 11, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W Black Solarization
The speed of the color wheel needs to adjusted or the CCA values. Both are found in the service menu . If you paid a company to fix the TV, call them and tell them that they forgot to perform these alignments. If you did the repair yourself, you'll have to call around for a price to have a Samsung service center perform these adjustments. I don't recommend consumers access the service menus of modern TVs because one wrong button push and you may cause irrepairable changes to the TV's proper operation.
michtech
Feb 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Changed samsung hlp6163 colorwheel now all the colors are off alot of blue
There is a place for a jumper on your DMD (the module that the color wheel plugs in to) If the jumper is there remove it. If there is no jumper install one. On later models the pins are gone but solder pads are still there, solder it. Some wheels have air bearing and others have fluid bearing. You really should buy a service manual for that set. New color wheels sometimes come with CCA values that you must change in the service menu
Good Luck
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
CCA Values For Samsung TV
With the TV off, you need to push
Mute-1-8-2-Power very fast. just wait and it will show up.
If the tv is on press Power-mute-1-8-2-Power and it will show up as well. Good luck, I am still trying to fix the CCA values myself. When you get in the Service Menu, just use the arrows to get around and to get back use the menu key.....
Jun 11, 2008 | Samsung Televison & Video
Samsung HLP4663W color wheel replacement
When I removed the jumper wire the screen color problems I experienced after changing the color wheel were fixed completely. I did not need to reset the CCA values (which came with my color wheel, on a separate sticker). If you have a black bracket blocking access to the jumper wire, as I did, you can access the jumper wire by removing the fan shown just to the left of the yellow and white sticker; there are two screws attaching the fan to the chassis below it. Next, remove the two screws that hold the silver clamshell (the housing for the circuit board) halves together. These screws are right behind where the fan just was, on either side of the protruding fins. They each have a spring under the screw head. You can then pull the visible half of the silver housing forward (with the bracket attached). You will then have access to the entire circuit board. Look for CN810 - it is located right behind where that bracket just was when it was all put together. Pull the tiny black plastic part (that has the jumper wire) off of the pins. Then reassemble the housing and put the fan back on.
Jan 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
515 people viewed this question
Top Televison & Video Experts
