I have a refurbished Gateway T-1625 notebook that up until now has worked fine. However, a few days ago the wireless capability just stopped working. Now, when I try to connect via wireless, it says there is nothgin within range, and when I ask it to explain, it says that my wireless switch is turned off. I've checked numerous times; it isn't.
    Genius:
  • 1,124 Answers
If your laptop is not "on range" this problably respond to:
1) Interference problem or bad signal.
2) Bad hardware devices (cards, routers etc)
Check your wireless router (turn it off in a while and see what happen)
Check your wireless card adaptor in your computer (My PC >> right click Properties >> Hardware >> Device Manager >> Network)
Let me know how it is going!
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Posted on Oct 17, 2008
Phone doesn't ring
seems like since it was refurbished, it night of finally decided it was time to stop working, unfortunately tried to see if there was support for this model there is none.
Aug 13, 2014 | Toshiba EKT-6510S Speaker Phone Charcoal /...
Gateway M-1625 not showing anything on the screen
hmm depending on age of computer this might be a few things
try this first
turn off computer
Press F8 to get SAFE Mode while turning back on
see how that works.
report back please
May 26, 2012 | Gateway M-1625 Notebook
Gateway laptop wireless button
Hold down Fn key and hit F2. It will be used to turn on and turn off the wireless switch.
If you have window vista, Click Start, All Programs, Accessories, Window Mobility Centre, Turn Wireless On.
Apr 15, 2010 | Gateway T-1625 Notebook
I spilled a small amount of beer on my gateway m-1625 laptop and now everything seems to be working except the screen so i am trying to take it apart. i have taken most of the screws out but it still wont...
If your have the time, Hose down the pc with windex, through the leyboard, and any other openings that are available. Set the unit aside for at least three days in a warm area. This will dissolve any beer residue and allow the windex to totally evaporate. Try to run the unit after you are fully sure that all of the windex has evoparated.
You should be good to go unless you have burned out the video processor. If the screen still doesn't work, you can attach an external monitor to test it. If it works, you haven't burned up the processor, but you most likely have ruined the screen circuity.
If that is the case, then good luck. Go online and goole Gateway Notebook Repair. You'll have quite a few choices to select from.
Rich
Rich
Dec 15, 2009 | Gateway M-1625 Notebook
Gateway t 1625 laptop not booting
If u can, try to reformat it, reason i say this simple solution is because u already had the laptop looked at professionally, and due to you're laptop being stuck at the windows screen, i see this happen on HDD swaps a lot. The HDD needs to be repair-formatted or fully reformatted to talk to the new mobo when switched out, try this if all else fails, i personally think giving this simple solution may fix the boot up issue, but do make sure ur friend who looked at your laptop hadn't reset ur C MOS and may of not reconfigured it, this may also be the main cause of boot up troubles so make sure everything looks fine in ur BIOS. Gabriel will have a more proper solution than this but i believe by doing this it may help u bypass ur loading issue
Jun 24, 2009 | Gateway T-1625 Notebook
No wireless driver on my gateway t-1625
find your wireless card manufacture n serial number inside your backward laptop casing. there sould be any informations about your wifi card. find it up n download the driver form official website. go googling...
Apr 09, 2009 | Gateway T-1625 Notebook
My gateway 7330GZ with windows xp doesn't se my dvd-rw drive
un-install the drivers,then re-install after first restarting the unit.
if that does not work,replace the drive with a new one.
Jan 31, 2009 | Gateway 7330GZ Notebook
Gateway M-1625 shutting down few times a day
I am havin the same problem at the company i work at. The problem with our machines has to do with the mother boards. But you might want ot check the power supply and make sure it is rated high enough to run your system. Next check/blow out your CPU cooler, and go into bios and see if it is set up to shut off at a certain temp.
Dec 21, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
