Question about Jensen VM9510 Car DVD Player
Pioneer 4000 making it work without brake on
I just got the pioneer 4000 6.1 screen and wanted if anyone new how to bypass the brake so it works going down the road thanks
  • sandoinlove Oct 20, 2008
    it doesnt have a remote
  • mangu147 Jan 31, 2009
    hi wat remote did u use in these steps?????
Press setup on remote control.
After enterning the setup screen:
1) Select the "Language" tab
2) Once in the language selection menu, press: 543210.
3) A menu "secret" screen will appear, select the "Hammer and Screwdriver" button
4) Select "Brake Override"
5) Select "On"
6) Press "Setup" on the remote again to exit screen.
Posted on Oct 19, 2008
How to bypass parking brake
  • The parking brake wire is a ground engaged when you have the parking brake on. So just ground the wire. Make it a very solid ground or it won't work. You basically changing the grounding location from the parking brake to a different ground. When you put it on a new ground it will be active anytime. Where as with the parking brake, the wire only gets a ground when the parking brake is engaged, follow?
  • As far as just bypassing it flat out as in not using the wire you can't, not for viewing the screen anyway. The ground wire is a safety feature and must be grounded somewhere to view the screen.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 24, 2011 | Pioneer AVIC-F700BT Car GPS Receiver
I got a pioneer avhp 4000 and when i play a dvd
If you installed a bypass switch then I just had the same problem. Let me just go over the wiring that we will use. As of right now you should have the (green) emergency brake wire and a small (black) ground wire. There is also a larger (black) ground wire that you attached to the vehicle ground plug. You will need an extra length of wire, I used black because it was for ground. Attach one end of this wire into the connection of larger ground wires. Attach the other end with the end of the smaller ground wire. Then you will attach your switch, one wire to the two ground wires, and the green wire to the other. It sounds a little complicated and I hope I didn't confuse you, but what you are really doing in reality is creating two grounds to one end of the switch and the green wire to the other.
Jan 22, 2010 | Pioneer AVH-P4000DVD Monitor
How do u bypass the brake wire to watch dvd while driving?
put the brake wire to ground, but remember this is dangerous and you may cause an accident.
Jan 03, 2010 | Pioneer AVIC-D3 Car DVD Player
Is there a way I can watch a DVD movie on my Pioneer AVIC-Z2 screen without having to put on my parking brake?
Yes, there is a way to watch a movie without the parking brake engaged. The parking brake safety mechanism is there for a reason, and I do not suggest that you disable this sytem so that you can watch movies while driving. With that said, the simplest way to bypass the parking brake system is to take the parking brake wire from the head unit, run a wire to a chassis ground point, and then put a toggle switch inline so that you can flip it on and off. This will simulate the engaging/disengaging of a parking brake.
Again, I do not condone or recommend watching movies while driving. There are enough distracted people driving on the roads.
May 18, 2009 | Pioneer AVIC-Z2 Car DVD Player
Parking brake bypass
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Feb 11, 2009 | Pioneer AVH-P5000D Car DVD Player
E- Brake Bypass
This forum should have what you are looking for:
http://www.avic411.com/forum/viewforum.php?f=11&sid=d2e7eb58b07df6e1abc1cd149fb69b3a
Apparently, you are not alone!
May 22, 2008 | Pioneer AVIC-D3 Car DVD Player
Bypass NAVI
Ummm, its against the law for the driver of a motor vehicle to able to see the screen of a tv or dvd player while the vehicle is in motion! Dummy, watch the road!!!!!!!!
May 07, 2008 | Pioneer AVIC-Z2 Car DVD Player
Pioneer avh-p4900dvd
go to autozone or any parts store and buy a generic $5 relay.
1. connect "30" to the parking brake wire from the headunit
2. connect both "86" and "87" to ground
3. connect "85" to the remote turn-on wire from the headunit
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Bypass
is there an override code I could put in instead of the toggle switch?
Sep 26, 2007 | Pioneer AVH-P4900 Car Video Player
Jensen VM9510 Car DVD Player Logo
407 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
