Question about Daewoo KOC-925T Microwave Oven
Sparks! Every now and then, when running the microwave (not convection) it will issue a large spark inside the oven, even if there is nothing in it.
  • scudder Jan 09, 2009
    I also had sparks on my brand new Daewoo just one day old. It only sparks on the microwave setting. I was wondering if perhaps it was the paper towel wrapped around the sandwich I was heating up
    Scholar:
  • 84 Answers
Your oven have been damaged don't on it again and again.....
it need reparing of heeted wires inside the oven
plz. do not use it, its may be harmfull to you because sparks shutdown your all home light or chances of electric shock
Posted on Oct 17, 2008
MICROWAVE TAKES LONGER TO COOK EVEN ON HIGH AND OCCASIONALLY SPARKS FOR NO REASON
inside your micro... walls are made of metal but protected with paint, if this paint is gone and the metal shows thats what happend you have to repaint the unprotected areas again, and the reason your micro... is not working so good anymore is due to the magnetron
Jan 31, 2014 | Sharp R-930AK Convection/Microwave Oven
Microwave sparks
If it sparks inside the oven then look inside for any powder paint missing... if so discard. If you has metal shelves or tin foil then don't put metal in when on microwave setting. Some of these metal shelves are for a microwave that is also a convection oven but only in the convection oven setting.
Nov 26, 2013 | Thermador Microwave Ovens
What cause sparks to shoot inside the Daewoo KOR-1B4H Microwave Oven when it is empty?
You should never run a microwave with nothing in it!! There is nowhere for the energy to go. The oven itself has a special coating that keeps the sparks from happening. Anywhere the coating is bad will arc. If it keeps arcing it will burn out the microwave generator.
Oct 02, 2013 | Daewoo KOR-1B4H Microwave Oven
My GE microwave convection oven JVM1790SK 01. It has started to make a load grinding noise, and is sparking above the cavity area, otherwise it operated properly. When I remove the fan assembly part...
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
Nov 30, 2017 | GE JVM1790 Convection / Microwave Oven
Sparks when on microwave cooking
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kk
Apr 09, 2010 | GE Advantium 120 Convection/Microwave Oven
Sparks coming from back of microwave
If you coffee container had any metallic logos or paint on it sparks will occur. Try to heat water in the glass container.
Dec 11, 2009 | Daewoo KOC-925T Microwave Oven
Manufactured in 02, thi shas been a great unit
Sparks during convection heating? That may be a shorting convection heating element.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
If you still need help, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit as well as repeating your symptoms in detail.
Also, let us know where she saw the sparking and if the poor heating is in convection mode or microwave mode or both.
Nov 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Sparks in microwave/convection oven
Remove the plate and clean it with warm water
Jun 22, 2009 | Panasonic Microwave Ovens
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Problem
check halogen light holder and connections, and any damage body, check inside body of microwave oven , because of microwaves some sparks comes from damaged body..
Oct 18, 2007 | Kenmore 63793 Convection / Microwave Oven
Daewoo KOC-925T Microwave Oven Logo
176 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
