Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer Model A8420 Not draining completely
Late model maytag washer will not drain completely. Clothes coming out dripping wet. Any ideas?
  • 944 Answers
SOURCE: maytag washing machine #mav6260aw
If you are a good DYI'er you can find the parts here http://www.repairclinic.com/0003.asp you'll need a couple of hours set aside and maybe a few beers for after. If you are not going to fix it yourself the labor costs and parts would come
to just about the price of a new one. Hope this helps.
Posted on Nov 11, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Error COde "nd"
"nd" refers to a No Drain issue . check for rstriction in pump assy, restricted drain hose loose wire at pump, bad pump
Posted on Mar 03, 2008
I had a similar problem until it finally gave up draining altogether. I took the drain pump apart and found that a quarter was jammed in the pump after it broke a vain off. I don't know how the quarter got past the basket but this was definitely my problem.
Posted on Mar 29, 2008
kf4rwe
  • 25 Answers
SOURCE: maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Posted on Dec 03, 2008
jyackle5
  • 8197 Answers
SOURCE: My Maytag Legacy Series washer
You also might want to check the lid switch.
Posted on Mar 15, 2009
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune front load washer model MAH400AWW that will not drain properly. I have it set to "max extract" and the clothes come out dripping wet and there is always a significant amount of...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Maytag Washing Machines
Maytag model MAV208DAWW washer, clothes still damp to wet after spin cycle. DIYer, want to try to fix it myself.
excellent love a guy willing to try
ok wet cloths
with this model i would the first thing to check is the height of your drain,,,, if the drain ios highter than 6 feet the unit just cant do it
next check your belt, this sometimes becomes stretched, more than 1/2 deflection id change it
Oct 25, 2009 | Maytag Legacy MAV208DAWW Top Load Washer
Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
May 08, 2009 | Maytag HAV2557 Top Load Washer
Wet clothes after spin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer model a8420 won't drain
your drain pump is probably stopped up with something small socks are bad about getting in there
Apr 24, 2009 | Washing Machines
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer not agitating and not spinning fully
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
