Question about Whirlpool Washing Machines
Whirlpool washer spincycle
My washer will not go into the spincycle or get rid of the water
    Scholar:
  • 112 Answers
Most of the time, this is caused by a faulty lid switch.
Posted on Oct 18, 2008
How do i get rid of the key symbol
Push the buttons which have a key symbol for 3 seconds and the washer can be used after unlocking the child lock. Download your WHIRLPOOL AQUASTEAM 9559 WP user guide or user manual
Mar 08, 2015 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Top load washer, spincycle spins drum, wont pump water out of tub, about 10-15 yrs old machine
You need to clear out the drain pump. You do this by tilting the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. Hope this helps
Feb 23, 2011 | Maytag Centennial MTW5800TW Top Load...
The washer does not agatite
It sounds like something has gotten lodged in the water pump. Since the pump is directly driven by the
motor, the pump is always turning in the wash & spincycles. The pump is attached to the motor and turns
the entire time the motor is running. Other possibilities would be the motor or transmission.
However, you need technician's help to access the pump.
Hope this helps.
Please feel free to ask further queries.
Shane
Feb 12, 2011 | Whirlpool LSR5132PQ Top Load Washer
GE GSLS1100 Spacemaker won't spin or drain. Washes fine then makes a rattleling noise during spincycle.
When I first started using my washer when I hooked up the water it would fill the hose and then stop until I started the machine. Now when I hook up the washer to the faucet water starts to fill the machine before I close the lid and before I start the washing process....? The last time I used the machine it didnt drain and I had a flood, is there a problem with it now???
Jan 09, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
May 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Problem with whirlpool front loader
    Your water mixing valve is letting water in the machine between cycles. That is the valve that the hot and cold water hoses connect to in the back. Replace that valve to stop the water build up. Run a periodic cleaning cycle with a generous amount of white vinegar to rid the smell. Or you can buy a prduct called Affresh from a hardware store.
    Jun 21, 2008 | Whirlpool AWM5125/1 Front Load Washer
    Whirlpool duet front loading washer
    your inlet water valve is not closing and needs replacing, in mean time turn water off between washings.
    Apr 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    24 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
