Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox TV/VCR COMBO
Unit is currently stuck in VCR mode and we are unable to use the tv simply to watch tv...there does not seem to be any tv/vcr switch either on the television itself nor on the remote control. We have never had this problem before. Whenever we used the VCR in the past, regular tv programming resumed whenever the tape was either ejected or stopped to use fast forward or rewind options.
Any suggestions for a fix? I have already received the suggestion to never again buy this type of item...this advice does not ameliorate current situation.
Thank you!
    Problem Solver:
  • 6 Answers
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Posted on Oct 21, 2008
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help ยท Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
I record a DVD from VCR tape and try to play on another device
In my research, I learned about finalizing the DVD, which was a new concept to me. I looked that process up in the manual and it did the trick.
Nov 16, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr will not record
THE CABLE OR ANTENA NEED TO SCREW INTO THE INPUT OF YOUR UNIT THEN A SMALL WIRE OUT TO THE TV FROM YOUR UNIT PUSH RECORD WHEN SHOW IS ON TV !SO ITS CABLE INTO VCR INPUT THEN CABLE FROM OUTPUT OF VCR TO TV ....TV ON CHANNEL 3 AND VCR UNIT ON CHANNEL 3
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Can I connect a dvd player to a dvd\vcr combo
I am not sure I understand why you would hook a dvd player to your combo.You should just hook your magnavox directly to your tv.
Sep 24, 2007 | Televison & Video
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
178 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
