Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Ice dispenser little flap not closing after dispensing ice, build up of ice on inside
I am getting ice forming just inside the ice dispenser hole from the ice maker.  We have a whirlpool side by side with water ice dispenser in the door.  Need to know how to take apart front panel to see if the mechanism can be fixed.  Thanks
Bill Priese
  • jaws80_73 Nov 05, 2008
    The flap on the ice dispenser is not closing all the way. Trying to remove panel so I can see if it is just a connection problem or a broken part is needing replacement.
  • 4 Answers
You have apossibale air leak mixing with cold air from refer
Posted on Oct 17, 2008
THE ICE DISPENSER FLAP IS NOT CLOSING ALL THE WAY
There is a solenoid that operates the flap, although there are many other components that could be broke but usually its the solenoid
Jul 22, 2015 | Frost Refrigerators
Why won't my ice maker work
Hello Cynthia! Most likely the little "flap" inside the door of the dispenser is not closing all the way. My advice is to take all your ice out of the inside of the freezer. Clean and dry out that area as good as you can. Take your hand, and from the bottom, reach up and feel the flap that should close all the way when ice or water is dispensed. Take warm water, pour it from the top, you won't need much, and dry off the little flap as good as can be.
Now, press the ice button, and when you let go, you should hear a clunk or deep sounding slap, that is from the flap closing properly. Same goes for the water. However some manufacturers don't open the flap for water. From this point forward, assuming you heard the flap close, be sure it makes that same noise every single time you use the ice dispenser, or the water dispenser, and your problem should be solved.
May 07, 2014 | Refrigerators
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
The ice dispensing flap on the door doesn't close completely. I have a GE side by side with water and ice through the door.
COULD BE DO TO ICE BUILD UP. IT MAY NEED A NEW GASKET OR FLAPPER DOOR. THIS NEEDS TO BE TIGHT.! . TO FIX THE LEAK TILL YOU GET THE PART USE A PLASTIC BAG AND A SOCK(CLEAN?) AND FROM THE INSIDE PLUG THE ICE DOOR HOLE ..
Jan 31, 2010 | GE Refrigerators
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Jun 26, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice forming where ice comes out to refrigerator
I am not sure if this is the same issue or not.  the flap that closes after you have dispensed ice does not close or seal all the way.  The gasket is worn down. the result is warm air get up into icemaker and warms ice and refreezes in one block so now the dispenser gets blocked.  We had to replace the flap in the door.  bought the part at an appliance part  store (not sears) they were helpfull and looked up the part needed.  Also a sheet of ice forms on the  bottom of the freezer.  When water is dispensed a small bit drips inside freezer in back and runs down to botom of freezer slowly forming a sheet of ice.  Use a hair dryer to defrost and then you must unclog the drain in the back at the bottom of ffreezer to allow it to drian.  Once we finally unclogged the drain we have not had any problems for about 2 years.
Nov 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire In Door Ice Dispenser
betz589,
I had the same problem and just finished fixing it myself. 1st, slide out your ice bin about 3-4" and look underneath it. There will be a long brass rod running along the underside of the ice and goes into a little square hole below the ice maker. This rod runs the flap on the dispensor and keeps it closed for crushed ice and opens the flap for cubed ice. The is a plastic bar inside the little square hole that needs to be moved. Slide your finger onto the plastic bar inside the square hole and move it either up or down. Slide the ice bin back in and try cubed ice. If it doesn't work, move the plastic bar the other direction. This will fix your problem...........Good Luck! Dennis
Aug 01, 2008 | Refrigerators
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
435 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
