Question about Radio Communications
My motorola GP900 has problems
My motorola GP900 transmiits on the 446 band but only when its very close to another radio, for example a maximum of a few centimetres away, it powers up ok and everything, what could be wrong with it
  • Radio Commun... Master
  • 1,654 Answers
Check for a bad antenna, wrong antenna, or no antenna. Switch antennas with a known good unit and see if the problem persists. If this does not solve the problem, you most likely have low transmit power, and the radio needs to be serviced.
Posted on Oct 18, 2008
Can you make a baby monitor out of the Motorola 250 model
hello yes you can use these as baby monitors .set one with vox on turn its volume down completly set the channel you require ,secondly the receiver radio set to same channel and that is it though i should state that these radios transmit on pmr band 446 mhz which is widely in use by many people nationwide so they can also listen in to whats been transmitted from your home not very private im afraid !! I would suggest you purchase a wired system hence more privacy and peace of mind hope this helps you
Nov 24, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola ht600e ARE THEY DEAF??
OK.. First thing you need to make sure that the soldier joints at teh base of the antenna are OK. ive programmed quite a few of these and found all but 1 not to be broken. So get in there and take a look. If in doubt touch the joints up with a iron just to be sure. Then tart with a weakish signal ( used a hand held with a dummy load on it in another room with a tv on as sound) and tune core L1 to get maximum clear sound. Then do the same for L2. Then reduce power on hand help thats being your signal source and repeat L1 and L2 Tuning. Some times these radios have teh wrong antenas on them. as in a VHF and not a UHF. but ive yet to come across this my self.
Hope this has been of help..
One last thing. the pins from the prog plug also break off teh main PCB so while ur touching up the antenna stuff do these at the same time.
Cheers
Dave UK G7
Nov 05, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
How culd i program a mt 2100
Needs Motorola software and RIB box.with programming cable $$ It is a very specialized professional radio for a specific use.
Oct 08, 2009 | Motorola For MT2000 HT1000 HT6000 GP900...
Need Mt2000 owners manual
We were unable to find one posted on line. The part number is 6881076C65. It is available from your nearest authorized Motorola dealer for $30-$35 (US dollars).
You might check with your local law enforcement, as this is a common radio they might have used. It is possible you might find a manual through them.
Jan 25, 2009 | Motorola For MT2000 HT1000 HT6000 GP900...
MOTOROLA RADIUS GP900
Unprogrammed channels will have a constant tone. It is possible your radio is unprogrammed. A dead battery tone is only for a moment, and is usually a medium tone then a low tone, sounding somewhat like beeedeeep.
Dec 06, 2008 | Radio Communications
Motorola HT 1000 programming cable
Sorry to let you down, but the cable will only function with the appropriate Motorola software (and possibly a radio interface box (RIB) if the cable type you have requires one.) Software is only available to dealers. If you are needing reprogramming, it is generally available for between $25-$40 US.
Nov 17, 2008 | Motorola For MT2000 HT1000 HT6000 GP900...
Motorola HT 1000
Your radios might need reprogramming. This is done by a Motorola dealer using the appropriate cable and software. The software is not available for end-users. Cost generally is $35-$40 US.
From the information you provided, it is unclear if the radios previously worked together; or if the radios are the same model number. These are facts the dealer would be able to inquire about, and it would help them determine if your radios can talk to one another.
Looking for Motorola HT 1000 manual 68P81079C50-0
6881079C50 is the part number you need. It should be available from any US Motorola dealer for $15-20. (Note: I could not find one posted online.)
Nov 16, 2008 | Motorola For MT2000 HT1000 HT6000 GP900...
Radio Communications Logo
206 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
